> Fog Light Relay, Where is it located
post Sep 26, 2003 - 10:55 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
For those that have them I have a question or 2.
1. Where is the fuse located exactly? Bcus when I looked at the panel it shows what fuse # it is (20A I believe for FOGS), but I can't find it? There's the exposed fuses right when you open up the panel then just below that there's a black "box" that's covering up I guess more fuses?? confused.gif
2. If I have the harness already in there from stock an I connect the fog light to the harness will my ST wiring work or will I have to re splice everything and make my own switch?
post Oct 1, 2003 - 2:46 PM
CelicaQT
Joined Sep 29, '02
*bump*
Lo-Fi Version Time is now: November 29th, 2024 - 12:07 AM
