Energy Suspension sway bar bushings |
Oct 23, 2008 - 5:34 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
I want to get new rear sway bar bushings to get rid of any noise the old ones might be making, and I say that Energy Suspension makes universal bushings based on the size of the bar. I measured the rear sway bar with a dial caliper and it's 16mm.
http://www.energysuspensionparts.com/Unive...ar-Bushings.asp I believe we have non-greaseable bushings, so it should be these: http://www.energysuspensionparts.com/prodd...asp?prod=9.5120 If someone could confirm dimensions of the brackets that would be awesome. This would be a nice and cheap little upgrade. I would do my fronts as well if someone knew the size of it so I can confirm which set to buy (they have an A and a B). This post has been edited by GotToyota: Oct 23, 2008 - 9:14 PM |
Oct 23, 2008 - 5:39 PM |
I thought it was determined that the OEM Toyota bushings were inexpensive and just as good?
Oct 23, 2008 - 8:09 PM |
Oct 23, 2008 - 8:23 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Maybe it's just my computer, but the links aren't working for me.
What kind of measurements on the brackets do you need? I just replaced my sway bars today so I have the factory bushings and brackets sitting around to get measurements from. -------------------- |
Oct 23, 2008 - 9:13 PM |
Maybe it's just my computer, but the links aren't working for me. What kind of measurements on the brackets do you need? I just replaced my sway bars today so I have the factory bushings and brackets sitting around to get measurements from. I fixed the links. Look at the first link under non-greaseable bushings, I just need those bracket measurements compared to the factory ones. -Matt This post has been edited by GotToyota: Oct 23, 2008 - 9:13 PM |
Oct 26, 2008 - 11:15 AM |
Anyone?
Lo-Fi Version | Time is now: December 3rd, 2024 - 3:36 PM |
