Seat Belt Full Retracted, Is there a way to undo this? |
Oct 25, 2008 - 11:45 AM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
So.. as part of the full disassembly of the interior... genius let the rear seat belt fully retract and we're pretty sure that its locked in that state for safety? / reuse concerns? Anyone know how to get the seat belt out of this state or if thats it... one and done no mas?
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Oct 29, 2008 - 12:15 PM |
Enthusiast Joined Jun 14, '07 From Bremerton, WA Currently Offline Reputation: 1 (100%) |
So.. as part of the full disassembly of the interior... genius let the rear seat belt fully retract and we're pretty sure that its locked in that state for safety? / reuse concerns? Anyone know how to get the seat belt out of this state or if thats it... one and done no mas? I've got a 93 MR2 (I'm guessing the seat belt hardware is probably very similar if not the same) and this happened to me one time. I found that there was a ball bearing inside, which you could see through the clear plastic area of the side of the rolling mechanism. I'm assuming it's meant to keep the seatbelt locked in case the car rolls over, etc. I had to balance that out while slowly pulling on the belt. It finally came loose. You'll have to look around and see if there is a safety release switch on it as well. Good luck! |
Oct 29, 2008 - 12:31 PM |
Oh Man... sounds fun... thanks for the tip!
Oct 29, 2008 - 11:16 PM |
it happens any time the belt case is not in the position it was installed in the car. bolt it back up and you should be able to pull it back out.
Lo-Fi Version | Time is now: January 10th, 2025 - 4:56 PM |
