> Brakes creaking, when going forward
post Oct 27, 2008 - 2:07 AM
kamax
Joined Apr 29, '03
From lynn,ma
My brakes are creaking really badly when I am in a forward motion and hitting the brakes. But in reverse this doesn't happen. Anyone know the cause? I've changed brake pads and rotor about 6months ago, as far as I know, I havent done anything to merit a warp rotor... but than again i could be wrong.
post Oct 27, 2008 - 2:29 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
did you resurface the rotor?? or maybe those warning pins bent inwards and are now contacting with the rotor??? did you also install those anti-rattle shims thingy??
post Oct 27, 2008 - 11:01 PM
kamax
Joined Apr 29, '03
From lynn,ma
they were brand new rotor i ordered. I'll have to take em out again and check i guess.... maybe more brake grease would help heh
post Oct 28, 2008 - 12:35 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
maybe a caliper clip could be rubbing against the caliper if there is rotor or hub runout. try taking the tire off and rotating the rotor to see if the pad moves side to side.
post Oct 28, 2008 - 2:30 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Sorry to hijack, but what would be the cause for squeaking drums? I think my front discs are fine, I just hear the drums in back...
post Oct 28, 2008 - 2:34 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Brake dust causes squeaking drums. Well not quite squeaking, but more of a loud high pitched... rrrrrrrrrrrrrrrrrrrrr. Lotsa dust gets caught up in those things. Could also be time for new brake shoes, depending if yours have ever been replaced or not (they last a really long time since most of the load is on the front brakes).
post Oct 28, 2008 - 2:37 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
I have no idea if they've been replaced at all...quite frankly, I never even had a mechanic check anything, just assumed the dealer handled everything.
I'm assuming the "cherry" car they sold didn't have any imperfections...I was mostly right. biggrin.gif
post Oct 28, 2008 - 3:16 PM
GriffGirl
Joined Feb 7, '07
11 yrs old w/70k in itself qualifies it as cherry unless it's a salvaged title tongue.gif
If you've got the money, this would be a perfect opportunity to do the rear drum-to-disc conversion. It's not that much more than having to replace the drums and shoes anyway - drums and shoes cost more than pads and rotors. That is, of course, assuming you're doing the labor yourself and not paying someone to do it.
post Oct 28, 2008 - 3:28 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
QUOTE (GriffGirl @ Oct 28, 2008 - 3:16 PM) *
I wouldn't entirely trust myself with the labor, nor do I really think it's necessary. I tend to drive carefully, so stopping power isn't a giant concern to me. *knocks on wood* I would drop cash into other areas first...I still have to small dents to get out first, but they shouldn't cost me much more than $100.
post Oct 28, 2008 - 4:05 PM
GriffGirl
Joined Feb 7, '07
That's a good approach to take; I can appreciate that!
post Oct 28, 2008 - 5:41 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Lo-Fi Version Time is now: January 8th, 2025 - 10:39 AM
