E153 Gearbox into a ST202 |
Oct 30, 2008 - 3:01 PM |
Enthusiast Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
Hi, I have fitted a 3SGTE engine into my ST202 droptop. Also fitted is a E153 gearbox. This conversion has been done before, but I can't find the thread. I want to know what drive shafts were used as the GT drive shafts will not fit into the E153 box. Do I use ST205, ST185, ST165 shafts?
This post has been edited by jeffrosie: Oct 30, 2008 - 3:01 PM |
Oct 30, 2008 - 8:43 PM |
http://www.6gc.net/forums/index.php?showtopic=32626
good luck reading all that basically, 91-93 MR2 turbo (non-lsd) inners and 90-93 all-trac outers. The general agreement is that you will need about a 12mm spacer on the passenger side, and most don't need a spacer on the driver's side. I used a 12mm spacer for both sides with my st205 e153 swap and no problems. -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:21 PM |
