> too slow
post Nov 3, 2008 - 6:43 PM
kool-94st
Joined Jan 29, '08
From san jose
im tired of how shlow my celica is whats the best way to make my celica faster with not so much money?
post Nov 3, 2008 - 7:05 PM
96bluevert
Joined Mar 19, '07
From Washington
Unless you do an engine swap or turbo, there isn't anything that will make a really big difference.
post Nov 4, 2008 - 4:02 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
premium gasoline, pod filter, cannon muffler, a well designed cold air intake, ngk iridium spark plugs, oil blowby catch can, intake manifold flush (use carby cleaner) and polish (fine sandpaper/dremmel).
all the newbie DIYs, cheap and easy stuff. use the search feature on this stuff, 6gc's info pages have some stuff too.
Mike W
269awhp / 273ft-lbs
post Nov 4, 2008 - 8:46 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE (delusionz @ Nov 4, 2008 - 4:02 AM) *
Sadly, the only thing that could show any real improvement here is the intake. Premium gas does nothing if the computer isn't tuned to utilize it.......a cannon muffler really does nothing if you don't open up the restrictive exhaust ahead of it..........spark pugs do NOT gain you HP (if your old ones are shot you can recover HP, but you won't gain anything).........a catch can helps prevent detonation if you're getting excessive oil through the PCV but that's about it...........intake manifold flush, that's just going to clean it out.
Like was said before, unless you can do a turbo motor swap or a custom turbo setup, you really won't see anything that noticable.
Now, if you can't afford the above, about the best you're going to get is with a well designed CAI as stated above, in conjunction with a header and full length exhaust. That's enough to make a noticable difference, but it's still not going to be that quick.
post Nov 4, 2008 - 9:36 AM
delusionz
Joined Feb 11, '08
Since he's got fk all cash he shouldn't bother with the exhaust because he'll be driving the car for months with no mods trying to save up for 1 mod.
Mike W
269awhp / 273ft-lbs
D-Man
Joined Jan 18, '08
From Houston
This
This
and
This
Will do absolutely nothing but waste your money. Same as any like item. Before you post up on something like these items, Asking if they indeed work... Please SEARCH. The Stickys are a massive archive of our cars, and making them fast. Check the dyno sheets, Read the build threads. Then get on "HowStuffWorks.com" And "Wiki.com" You'll be a pro in no time. biggrin.gif
Damn D-Man - most impressive.
post Nov 4, 2008 - 10:16 AM
Add45
Joined Sep 1, '08
From STL
lmao u scared me for a second^
post Nov 4, 2008 - 12:27 PM
tomazws
Joined Oct 30, '04
From So Cal
Sell the car and get something else.
Lo-Fi Version Time is now: November 27th, 2024 - 6:25 AM
