![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '07 From Sunny Florida Currently Offline Reputation: 18 (91%) ![]() |
Sean is on vacation last time we talked.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) ![]() |
Sean is on vacation last time we talked. I'm back, but I've been tinkering. For some reason the last coat of epoxy I put on the parts is NOT setting, and I can't understand why because I mixed it just like before. Right now I'm trying to figure out how to salvage the already done work, otherwise it's strip everything and start from scratch again. -------------------- |
maybe some heat. Let it set in the sun, helps with paint.
Ok, back on this. While I'm trying to strip Ricky's headlamp cover of the stuff that won't set, I decided to try something. Took a typical tall kitchen back and used it for vacuum bagging. The thinner bag should conform better and it's got a lot of stretch capability.
DAYUM. I hit a home run with that idea. Right now I'm curing a drivers door switch panel and a drivers upper dash vent piece, both of which I wrapped during hte last two days. VERY VERY pleased with how they're looking: ![]() ![]() This was hand wrapped, and I'm on the fence as to if I'm going to use it or not: ![]() NONE of these are finished yet. I hvae edges to trim and finish up and there's only one layup coat of epoxy on there right now, hence the rough spots. Pay close attention to the switch recesses on the door switch panel though......see how straight the weave remained as opposed to my hand layed piece? Vacuum bagging is the ish. ![]() This post has been edited by Fastbird: Jun 27, 2009 - 12:51 PM -------------------- |
Enthusiast ![]() ![]() Joined Apr 25, '09 From Ohio, USA Currently Offline Reputation: 0 (0%) ![]() |
have you tried a hood or anything big?
-------------------- I still own my celica, but i'm parting it out and junking it.. Or selling as a whole. Have a honda prelude now :(
have you tried a hood or anything big? Nope, and I don't plan to. I have zero interest into getting involved with something on that scale. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) ![]() |
Lookin reeeeeaaaaal nice Fastbird. Can't even tell you're new at this.
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
Lookin reeeeeaaaaal nice Fastbird. Can't even tell you're new at this. thanks man. I started sanding the drivers door switch last night and am VERY happy with how it's coming out. There's room for improvement but this piece is going to be a winner once I clearcoat it. Just have to get all the rest of hte pieces done in the same fashion now. Best move I ever made movign to a more pliable bagging material. -------------------- |
![]() Enthusiast ![]() Joined Nov 15, '07 From Attleboro Mass Currently Offline Reputation: 1 (100%) ![]() |
If I had the money I'd totally send some stuff out to you
-------------------- QUOTE Surprise buttsecks always works fine for me. 1994 Toyota Celica ST 1977 Harley Sportser XLH 1992 Ford F-350 (plow truck) |
Sanded epoxy and a fresh shot of clear coat. It's got some texture there because I JUST shot the clear. It should level out quite nicely and only need a minor 2000-3000 grit hit and polish to finish it off.
![]() ![]() This post has been edited by Fastbird: Jun 29, 2009 - 9:15 PM -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) ![]() |
Out of curiosity, are you still taking in 6gc member parts to wrap? I want to get some stuff on my bike wrapped (Ram air ducts, rear sets, mirrors, gauge bezel, bar sliders, frame sliders, chain protector).
I figure I'll either send them to you, or try and figure out how to do it myself (though I don't have a vaccuum packing machine, and would have to do a lot of trial and error). The parts should be fairly simple, the rear sets will probably be the hardest of all. Obviously, time and parts would be compensated. -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Out of curiosity, are you still taking in 6gc member parts to wrap? I want to get some stuff on my bike wrapped (Ram air ducts, rear sets, mirrors, gauge bezel, bar sliders, frame sliders, chain protector). I figure I'll either send them to you, or try and figure out how to do it myself (though I don't have a vaccuum packing machine, and would have to do a lot of trial and error). The parts should be fairly simple, the rear sets will probably be the hardest of all. Obviously, time and parts would be compensated. -TC I am on a very small basis. It's actually VERY easy to do a vacuum bagging setup. You only need an old refrigerator compressor to use as the pump ($50-75 for a good one, I Paid $80 for a new one), some tubing, some tacky tape, and some trash bags. YOu could go professional and use release film and filler, but I found I like it better with the bag only. Gets a tighter pull. Email or pm me some pics of what you want done and we can talk. I'm getting a LOT of requests right now and don't want to take on more than I can handle. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
you will do whatever i give you, ho
you will do whatever i give you, ho You wanted those parts trimmed in pink fluff right? -------------------- |
you will do whatever i give you, ho You wanted those parts trimmed in pink fluff right? lol, pink fluff FTW ! -------------------- ![]() |
Enthusiast ![]() Joined Aug 12, '08 From Maryland Currently Offline Reputation: 2 (100%) ![]() |
any newss on how things are going with this?
![]() Enthusiast ![]() ![]() ![]() Joined May 15, '09 From yonkers, NY Currently Offline Reputation: 8 (100%) ![]() |
hey just wondering watz up. mainly because i def wanna do or get this done. looks so freakin awsome no comparison 2 a cheap vynl cf look a like wrap i got.
-------------------- *Thing i want for my car(i wish i had money)*
-light blue tint (next step will do this right after i get my paint job) WTB Reasonably priced Projectors just Lows |
![]() Enthusiast ![]() Joined Jul 9, '09 From CT Currently Offline Reputation: 2 (100%) ![]() |
Hey man, just wondering if you received my pm. I'm sure you getting swamped with them but just let me know. Thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
any pics of wrapped parts installed back into the celica!!
im liking this carbon fiber look. -------------------- Group buy to replicate Narrow E series transaxle parts
Anyone associated with this thread might as well give up, I sent Sean about $200.00 in 86 ALL-TRAC Parts [Hard to come by as it is]..One in particular was very rare and one of a kind that i hand made.Took me months to get perfect.I sent him these parts last January.Yes its been a FULL year, I've had my deals go bad as well but I've always cleaned them up...Sooner or later.Anyways, Just an fyi..I don't think Sean is coming back around here any longer.
Lo-Fi Version | Time is now: April 23rd, 2025 - 8:00 PM |
