> key ring light stay on?, can you keep it on?
post Nov 5, 2008 - 4:11 AM
alaNi
Joined Nov 24, '06
From Kansas City
how do you keep the key ring light on while driving? it fades out after about 5seconds after door is shut
post Nov 5, 2008 - 8:53 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
Rewire to it's own source.
post Nov 6, 2008 - 10:11 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
my lit ring is in the mail, so i was wondering the better source to wire in the led? is the green wire in the cig lighter good enough? is there a closer wire, im assuming the radio power is constant to keep the settings from resetting? same deal with the clock right? making them bad ideas?
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
post Nov 10, 2008 - 7:19 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
so, im gonna splice into the clock power line i guess unless its a constant power? bad idea? who has a better idea? im thinking of splicing the ciglighter instead... whats better? i also have a fuse tap kit i may use, i bought it for a "cold cathode dash light" idea that i decided against...
post Nov 11, 2008 - 12:44 AM
WWSideWinder
Joined Oct 2, '08
From New Zealand
I used Joined it to the light on the cigarette lighter.
I'm also working on having work with the dome light and a timer/dimmer circuit I'm working on.
WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~
Have a look at my thread for updates on my progress.
"http://www.6gc.net/forums/index.php?showtopic=63338&hl=0"
post Nov 11, 2008 - 11:44 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
wired it in to the ciglighter bulb, for the clueless outthere power is green wire, and white with black stripe is ground... it takes about 2.5 ft of wire to give the bulb a healthy amount of slack. use solder and heat shrink so you wont have to do it over when the wires get loose under a ghetto electrical tape splice...
im wanting a brighter bulb, maybe an led... the ring isnt the same brightness all around, guessing its typical.... any tips? also, the cig lighter bulb is burnt out any opinions on an led to fit?
post Nov 11, 2008 - 11:58 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (boosted95 @ Nov 11, 2008 - 11:44 PM) *
I just recently decided to take off the nasty green thing from that bulb on the keyring. The light gets alot brighter without it, and to color it, i used a red straw from a gas station i think, and it glows amazingly. the whole thing lights up right around, and its gives JUST the right amount of color.
cant help with the cig lighter thing, i condemned mine.
This post has been edited by samir0189: Nov 12, 2008 - 12:08 AM
My F/S Thread!
Ferdi says (11:29)
post Nov 12, 2008 - 2:54 AM
WWSideWinder
Joined Oct 2, '08
From New Zealand
Boosted95
Hi there to even out my light (not perfect but better) I use 3 layers of white paper in front of the Bright LED.
This stopped the Bright Point of light in front of the LED and helped the ring get a more even light.
If you ask I'll take a photo and post it for you.
post Nov 14, 2008 - 1:58 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
QUOTE (WWSideWinder @ Nov 12, 2008 - 7:54 AM) *
Boosted95
yes sir, please... and was it a 194led?
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 11th, 2025 - 5:14 PM
