TX6G2K9, Lets have another big Texas meet! |
Jan 1, 2009 - 4:14 AM |
Enthusiast Joined Jun 17, '06 From dallas, tx Currently Offline Reputation: 12 (100%) |
sounds great Alex
do you have a build thread on supramania or any of the other supra forums? we'd love to see pics we are working on Vadar, getting the suspension all fixed up & pulling the motor/tranny tommorrow -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
'90 ST185 Celica All-Trac 3S-GTE "Vadar" Turbo AWD Sith Stage 2 in the works '99 SXV20 Camry 5S-FE "Darth Maul" TRD Grocery Getter powah coming soon |
Jan 1, 2009 - 3:49 PM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
No build threads. Too lazy to keep up with them on a slowly progressing project. I've got very minimal pictures since I was more focused on trying to get the car running than I was on taking pictures. I've got a couple from back when I got the car in August last year, from March of this year, and like one or two from this past week. I'll try to get a couple more this week.
Current mods thus far: -3" Apex'i filter -3" Y-pipe -3" downpipe -USDM 2JZ cams -Megan N1 Turbo muffler (needs to be welded on) -3" Vibrant Performance Ultra Quiet resonator (needs to be welded on) -24x12x3" Front mount intercooler -2.5" intercooler pipes -MK4 TT Denso fuel pump -JDM 2JZ 440cc fuel injectors -Russel Stainless Steel Brake lines -Stainless Steel Hydrofan, clutch, oil pressure, and power steering lines -Blitz Dual Drive blow off valve (needs to be welded on) -52MM AEM UEGO wideband (Need to get a replacement) -52MM ProSport Premium Fuel Pressure gauge (hasn't been mounted) -60MM ProSport Premium Boost, Oil Pressure, Exhaust Gas Temp, and Water Temp gauges (haven't been mounted) -Lotek 52MM triple gauge pod (needs to be installed) -Apex'i Turbo Timer (halfway wired in) -Apex'i AFC Neo -Blitz SBC i-Color Spec-R boost controller -17x8" (f) and 17x9.5" ® MK4 Twin Turbo wheels -235/45-17 and 275-40-17 Kumho Ecsta ASX (bald) -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Jan 8, 2009 - 7:27 PM |
Enthusiast Joined Dec 29, '08 From Dallas, TX / Sugar Land, TX Currently Offline Reputation: 0 (0%) |
Seems this is a bit of a general Texas thread...
Well anyway I'm in Richardson most of the time, since I go to UT Dallas for college. But I'm in Sugar Land/Houston pretty often, for breaks and random trips. Looking forward to meeting y'all sometime -------------------- |
Jan 9, 2009 - 1:07 AM |
welcome DanAdamKOF - always good to see other Tx members check in
Alex, sounds nice - lots of nice parts there. i understand on the pics. since there are both joe & myself one person can stop & take pics so its a lot easier. aren't those MKIV 2jz Supra injectors 550's? the 1st & 2nd gen 3sgte's came with 440's & the 3rd gen 3sgte's & i thought all 2jz MKIV Supra's came with the 550s. we got Vadar's engine & tranny out last weekend. good thing we are doing all this work ... motor was leaking oil all over the place. gotta rebuild the dizzy & the camshaft seals are shot. hopefully the oil pump isn't leaking too ... been cleaning up all the old oil/gunk just to see where it's fresh & where it isn't. suspension is almost done .. only the rear trailing arm bushings are left to replace. i've got a massive build thread but you have to be a registered member on alltrac.net to see all the pics. i can post a couple pics here, but i'm not going to redo the whole thread as it's too many pages. -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
Jan 9, 2009 - 4:02 PM |
Only the USDM 2JZs got the 550s, the bigger cams, the beefier turbos, and couple of other odds and ends that allows it to have the 320hp or so out the door. All JDM models got the 440s, smaller cams, and ceramic turbos (or steel. can't remember which) cuz of that gentleman's agreement who-ha that limit them at 280.
Here's a relatively cheap oil pump. http://cgi.ebay.com/ebaymotors/88-95-2-0L-...18001QQtcZphoto I'm not sure if it's the same one you're needing though. But I'm sure it's cheaper than Toyota. I spoke with the seller and they said that their parts are Aisin parts (as you can see in the picture) which is pretty much OEM parts. They've got a gasket set as well if you guys aren't able to get the cam seals by themselves from Toyota. http://cgi.ebay.com/ebaymotors/95-2-0L-TOY...91215QQtcZphoto http://cgi.ebay.com/ebaymotors/90-95-2-0-T...56576QQtcZphoto Good luck with it all! Hope to see you guys come down and visit us for our TX2K9! I'm hoping to participate in the drag runs if not the dyno. -------------------- -Alex {](O_o)[}
Jan 9, 2009 - 6:16 PM |
gotcha on the JDM 2JZ's ... i forgot all about the less than 300bhp gentlemen's rule.
thanks for the links on the oil pump & gasket. if we need a new oil pump i may just go ahead & get one from a (i think) '98+ Camry 5sfe... it's actually a higher flow pump than a 3sgte one. i was able to get the camshaft seals from toyota .. only $5 bux a piece or so for those. i do need to order some more gaskets though - may go ahead & do the rear main seal while the motor is out since i know it's never been done before. i'm really not sure if we are going to be able to make TX2K9 this year ... the only way we could come down would maybe be in the MR2 & that's only going to be if a GT-Four friend from Netherlands comes down for the event & even then i just don't know if we can afford to do it or not with spending so much $$$$$$$$$$$$ on parts to get Vadar going again. -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
Feb 2, 2009 - 2:27 PM |
Its my B-day! lol we still doing this??
I'm excited for it -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Feb 2, 2009 - 2:35 PM |
Enthusiast Joined Apr 15, '07 From san antonio tx. Currently Offline Reputation: 12 (100%) |
Happy b-day im down no matter what. Is it gonna be in march or what?
-------------------- Sorry, no animated sigs allowed.
Feb 2, 2009 - 3:23 PM |
when is TX2K9 again?
i think that will have something to do with setting a date for our meet. Vadar's motor is still in the living room & i'd say we're at least a good month to 2 months to getting him going again. We're trying to delete/remove the ABS & Toyota discontinued 3 of the Non ABS brake hard lines & I am having one helluva time trying to locate some 5th gen ST18x Non ABS lines either from someone parting them out or from a junkyard up here Anyone know of any 5th gen Celicas W/O ABS in junkyards near them? I'm getting desperate! -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
Feb 2, 2009 - 4:05 PM |
Enthusiast Joined Feb 17, '07 From Houston, TX. Currently Offline Reputation: 0 (0%) |
when is TX2K9 again? i think that will have something to do with setting a date for our meet. Vadar's motor is still in the living room & i'd say we're at least a good month to 2 months to getting him going again. We're trying to delete/remove the ABS & Toyota discontinued 3 of the Non ABS brake hard lines & I am having one helluva time trying to locate some 5th gen ST18x Non ABS lines either from someone parting them out or from a junkyard up here Anyone know of any 5th gen Celicas W/O ABS in junkyards near them? I'm getting desperate! There is a pic-a-part out here in Houston, they had about 8 5th gens last time I went. Im going out there next week Ill take a look for ya!! |
Feb 2, 2009 - 8:05 PM |
Supra TX2K9 is the weekend of the 19th. I think I'm about ready to sell both cars at this rate now. :-\
Feb 2, 2009 - 11:10 PM |
^ I'm with you Alex - I'm so exhausted I don't know what to do right now
Thanks Ironic. I called around & supposedly one place I called said they had 10-12 5th gens so we're going there this weekend. The downside is they are the most expensive junkyard known to man but at this point I just don't even care as long as they have the lines I need. -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
Feb 12, 2009 - 1:12 AM |
Enthusiast Joined Jul 14, '03 From Jacksonville, FL Currently Offline Reputation: 2 (100%) |
I'm going. But ya'll need to get organized.
Feb 12, 2009 - 2:00 AM |
Enthusiast Joined Jul 7, '06 From Los Alamos, NM Currently Offline Reputation: 1 (100%) |
I'm going. But ya'll need to get organized. really? just visiting texas? -------------------- 2015 Subaru WRX. World Rally Blue/Black
2001 Honda S2000. Spa Yellow/Black |
Feb 12, 2009 - 2:07 AM |
I'm going. But ya'll need to get organized. really? just visiting texas? just to go and meet people. i went to a california meet. now it's time for texas. it better be a big turn out! (bitches) This post has been edited by Jen: Feb 12, 2009 - 2:09 AM -------------------- |
Feb 12, 2009 - 2:15 AM |
TX2K8 how about 13-14 celicas there at one point. some canyon driving and texas food
going to bring the z? you and your boyfriend? or just you -------------------- 2015 Subaru WRX. World Rally Blue/Black
Feb 13, 2009 - 9:54 AM |
when is this? i'd like to know so i can go.
Feb 13, 2009 - 1:03 PM |
we're planning on sometime in May stephen.
i've got to find the maps so i can post up what routes we would like to take from Austin up to Marble Falls - it won't be for the faint of heart or faint of back to back twisties i know at least one other ST185 is coming along who lives in Austin. there is a ST165 in Austin i'm hoping will be able to come & i might be able to get some other ST185's i know in OK & MO to come out also. i think it's just a little early to be making exact dates given that May is quite a few months out. so we're not disorganized - i'm going to be working hard to make sure this is not disorganized nor chaotic like the last supra meet a few of us went to. -------------------- '87 AW11 MR2 "Super R2" 4AG-ZE swapped Stage 1 Complete
Feb 13, 2009 - 2:51 PM |
I think Jen said she might be coming down for the Supra meet, but I'm not sure if she meant our actual 6GC meet. *shrug*
Either way, I can't wait! -------------------- -Alex {](O_o)[}
Feb 14, 2009 - 1:27 AM |
we're planning on sometime in May stephen. i've got to find the maps so i can post up what routes we would like to take from Austin up to Marble Falls - it won't be for the faint of heart or faint of back to back twisties i know at least one other ST185 is coming along who lives in Austin. there is a ST165 in Austin i'm hoping will be able to come & i might be able to get some other ST185's i know in OK & MO to come out also. i think it's just a little early to be making exact dates given that May is quite a few months out. so we're not disorganized - i'm going to be working hard to make sure this is not disorganized nor chaotic like the last supra meet a few of us went to. GOOD. I love hardcore twisties. too bad my puny 7a and stock(200+k miles) suspension don't But May is still a bit away, maybe i can round up the extra cash for new shocks/springs and such -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Lo-Fi Version | Time is now: January 10th, 2025 - 11:55 AM |
