Fogs won't turn on. |
Nov 16, 2008 - 12:15 PM |
You have a '97, meaning your car is prewired for those fogs. All you need is the stalk w/ fog switch, the relay, and the fogs which you already have. The plugs for them are hanging behind the fog light itself. If the used the factory wiring for them they would only come on when your headlights are on.
I would suggest you get a stalk and relay and hook up the fogs the way the should be, that way you know they won't cause any problems. -------------------- |
Nov 16, 2008 - 2:38 PM |
Enthusiast Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
I see your point, but I was fine with the way it was before so I don't see a need to change it, just wanna get it right again.
Nov 16, 2008 - 4:54 PM |
Then you need to figure out how they are currently wired in so people can properly help you troubleshoot the problem.
Nov 16, 2008 - 8:32 PM |
I get your point...but I'm assuming they're factory wired like you said? Only the switch is placed above the left side vent.
Nov 20, 2008 - 7:55 PM |
again...
Then you need to figure out how they are currently wired in so people can properly help you troubleshoot the problem. Don't assume how it's wired and make sure, people can't help you properly with only information based on assumptions. Check for the relay Dustin (Batman) mentioned on pg2, take the fog lights out and see if they're plugged into the stock wiring, follow the wiring from the switch on the inside and see where it splices into. This post has been edited by hurley97: Nov 20, 2008 - 7:59 PM -------------------- |
Dec 6, 2008 - 8:13 PM |
Flipped the switch for poops and giggles and they magically came on...so it's not a fuse. Now the problem is figuring out where the wires are loose and not properly grounded. Would it be advisable to keep them off since I was told that an electrical fire could be started? They've worked properly ever since though.
Lo-Fi Version | Time is now: December 3rd, 2024 - 9:01 PM |
