> 4 channel Amplifier Install, Does anyone know how to wire up a 4 channel amplifier?
post Nov 11, 2008 - 8:04 PM
Aleksa
Joined May 13, '08
From Australia
Hi I've recently installed a headunit and front and rear pioneer speakers. I also have a 4 channel pioneer amplifier and was hoping to use that to power my speakers, only problem is i've never installed an amp before, i did the head unit and speakers but an amplifier is a bit scary. I also have a 15 inch kicker L7 subwoofer sitting in my garage. Just wondering wether anyone know's the box specs for that sub for a vented box. I tried kicker but all they have is 8, 10 and 12 inch specs and they aren't emailing me back either. But yeah any input on wiring a 4 channel amplifier would be greatly apriciated... thanks...
post Nov 11, 2008 - 8:09 PM
Ugglan
Joined Jan 8, '08
From Sweden
Are you using the amp for the speakers only or do you also want to connect the sub to it aswell?
I don't have a answer but I'm looking at a simular setup some day (when i got the money) smile.gif
post Nov 11, 2008 - 10:21 PM
WWSideWinder
Joined Oct 2, '08
From New Zealand
Amp Sert up wil be something along the lines of
Front Left + and -
Front Right + and -
Back Left + and -
Back Right + and -
My Setup is this.
I'm running 6.5" 3 way in the front doors with tweeters in the "Sail" (See "Curren updates" for the location)
6.5" 2 way in the back.
These are running off my 45Watt head unit and are plenty loud for me.
My Sub is running off a 4 Channel Amp but set up like this.
The front left and right channela are not used.
I have bridged the rear left and right. This gives me double the wattes for the sub than using a single channel.
This setup may suit you (Flames comming my way I can see) but a lot of people will tell you that th esound from an amp that is not being pushed will sound better. Me I'm happy with what I have.
You have not stated the Wattage of your Amp nor your head unit so I cant be more specific than that.
I strongly suggest you get a good 8 guage or 4 guage wiering kit to power the amp and this wil lalso give you the amp power on lead and the RCA's.
I also suggest you search this site for more information.
1 more suggestion remember to run the power for the Amp on 1 side of the car and the RCA down th eouther to avoid interfearance.
Any questions and you can PM me (I'm not an expert but I did a lot of research befor setting up my system and I'm constintly trying to improve it) tongue.gif
WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~
Have a look at my thread for updates on my progress.
"http://www.6gc.net/forums/index.php?showtopic=63338&hl=0"
post Nov 12, 2008 - 10:08 AM
D-Man
Joined Jan 18, '08
From Houston
http://akamaipix.crutchfield.com/ca/learni...s/amp_guide.pdf
http://www.crutchfield.com/learn/learningc...ers_wiring.html
Damn D-Man - most impressive.
post Nov 12, 2008 - 12:19 PM
WWSideWinder
Joined Oct 2, '08
From New Zealand
post Nov 13, 2008 - 7:20 PM
Aleksa
Joined May 13, '08
From Australia
QUOTE (Ugglan @ Nov 11, 2008 - 9:09 PM) *
Yeah i'm just using the 4 channel for the speakers and i'm looking around for a nice mono block to power my sub...
post Nov 13, 2008 - 7:26 PM
Aleksa
Joined May 13, '08
From Australia
QUOTE (WWSideWinder @ Nov 11, 2008 - 11:21 PM) *
Front Left + and -
Front Right + and -
Back Left + and -
Back Right + and -
My Setup is this.
Thanks sounds simple enough. Yeah i got a 600 watt pioneer amp and i don't know how many watts my head unit is but it's a pioneer DEH-3050UB...
post Nov 13, 2008 - 7:30 PM
Aleksa
Joined May 13, '08
From Australia
QUOTE (D-Man @ Nov 12, 2008 - 11:08 AM) *
Hey thanks man this has everything i need to know. I'll try it out as soon as i get some time and post how it goes. thanks...
Lo-Fi Version Time is now: January 11th, 2025 - 6:41 AM
