noise near left rear wheel |
Nov 12, 2008 - 2:58 AM |
Enthusiast Joined Feb 19, '08 From Anaheim,CA Currently Offline Reputation: 2 (100%) |
There is a weird noise coming from the left rear wheel....the only way i can describe the noise is it sounds like a cricket continuously chirping....does anybody know what it could be?
-------------------- lol
Nov 12, 2008 - 10:53 AM |
an actual cricket! no, how bout a seized bearing, that keeps making your rotors warp and rub against your pads when you drive
Nov 12, 2008 - 11:33 AM |
is that an easy fix...how much would u say it would cost to fix?
Nov 12, 2008 - 1:55 PM |
$150 for the hub and wheel bearing, trimming rotors is $20 a piece, should do both sides..labor depends where you take it, i could do it for $40
Nov 12, 2008 - 4:17 PM |
$150 for the hub and wheel bearing, trimming rotors is $20 a piece, should do both sides..labor depends where you take it, i could do it for $40 but are u sure that it is the problem...i hear the noise even when im idle -------------------- lol
Nov 12, 2008 - 4:50 PM |
you never said that! maybe something is loose. tighten up the sway bar bushing, end links, brakes, etc
Nov 12, 2008 - 4:54 PM |
you never said that! maybe something is loose. tighten up the sway bar bushing, end links, brakes, etc oops lol...thanks man ill check it -------------------- lol
Nov 12, 2008 - 8:40 PM |
Enthusiast Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) |
can you hear it from outside the car?
- maybe a loose suspension part, broken spring if its coming from inside - empty your hatch. take everything out and repack it. could be a loose cover, spare, jack. could be an improperly latched rear seat (actually heard that one once or twice). my 0,02$ -------------------- |
Nov 13, 2008 - 1:38 PM |
Enthusiast Joined Nov 13, '08 From NC Currently Offline Reputation: 0 (0%) |
blown strut maybe?
Nov 14, 2008 - 11:26 AM |
Enthusiast Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) |
does it make the noise when you're standing still or only moving?
If its only when you're moving, I'd start checking your brakes too, possibly its a dust shield or something rubbing. -------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Nov 15, 2008 - 3:08 AM |
Enthusiast Joined Sep 22, '08 From markham Currently Offline Reputation: 1 (100%) |
I have the exact same problem! no clue what it is, mechanically retarded. Thought I'd just let you know you're not alone... Going to go with LEWFX on this and try to tighten everything up.
Lo-Fi Version | Time is now: December 2nd, 2024 - 7:12 AM |
