> St to gt front brake conversion
post Nov 12, 2008 - 2:18 PM
6g25th
Joined Nov 28, '05
As I said in my last post, I ordered powerstop vented rotors for my front brakes on my st, the rotors are for a gt and they don't fit. I didn't know that the front rotors on the gt were bigger then the st so I was just wondering if I could do a front brake conversion using gt components. I figured I would just get the front brake assembly from a gt and just bolt it up like I did with the rear conversion. I just want to make sure this will work, so will it?
post Nov 12, 2008 - 2:35 PM
why waste the money? when you can just buy the right rotors...
This post has been edited by playr158: Nov 12, 2008 - 2:36 PM
post Nov 12, 2008 - 3:02 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
seriously, sell the GT rotors and get ST
post Nov 12, 2008 - 7:39 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
You can switch to GT front brakes if you want; you just need the calipers from any auto parts store (probably about $100 for the set), you need to source the caliper brackets from a junkyard or someone parting out a GT, you'll need new brake pads, and you already have the rotors.
Just to save the cost of returning the rotors, it's not really worth it.
I <3 Dustin---07/16/06
post Nov 12, 2008 - 10:39 PM
6g25th
Joined Nov 28, '05
I know it wouldn't be worth it, but the problem is that they don't make rotors for an st!!
post Nov 12, 2008 - 10:55 PM
as Hurley said, just get the GT calipers and brackets and they bolt right on in place of the ST parts.
post Nov 13, 2008 - 7:13 AM
QUOTE (6g25th @ Nov 12, 2008 - 10:39 PM) *
uhhh yea, rotors are made for an ST...... (maybe not that company, but they are)
post Nov 13, 2008 - 12:49 PM
6g25th
Joined Nov 28, '05
I know they make performance rotors for the st, but yeah, powerstop only makes them for a gt. I may just return the rotors and get summit racing drilled and slotted rotors. The only reason I don't wanna do that is I'll have gold rotors in the back and silver up front!
post Nov 13, 2008 - 12:51 PM
here is a quick lesson
Function > Form
this is how cars should work
good luck
post Nov 13, 2008 - 1:02 PM
tomazws
Joined Oct 30, '04
From So Cal
Look for 'em in junk yards.
Lo-Fi Version Time is now: November 29th, 2024 - 11:35 PM
