> JDM Lights Brake Light
post Nov 13, 2008 - 4:21 AM
whatthe
Joined Aug 13, '08
From Australia
Alright im using the USDM harness on a JDM Taillight, whats shows now is either side will have one brake light showing. What i want is both sides having two on.
What i have noticed when installing the jdm lights, there are 4 sockets correct? only 3 have bulbs the last one didnt have a bulb. So im guessing if i put a bulb in there when i brake there should be the two section of the lights showing right?
Would the usdm harness do the same thing?
Also the bulb im after is 1157 correct?
ps. ops wrong section
This post has been edited by whatthe: Nov 13, 2008 - 4:23 AM
post Nov 13, 2008 - 4:24 AM
NGHTKD
Joined Feb 2, '06
well when i had jdm tails i used the AUS harness (not same as US???) and only 1 showed.
but a mate (TNGCLA used to own st205 on here), spliced the wiring so both the two red ones showed on each side.
post Nov 13, 2008 - 4:27 AM
whatthe
Joined Aug 13, '08
From Australia
QUOTE (NGHTKD @ Nov 13, 2008 - 8:24 PM) *
yeh pretty much i want it to look like this
did you remember when you installed the jdm taillights having only 3 bulb but 4 sockets?
This post has been edited by whatthe: Nov 13, 2008 - 4:30 AM
post Nov 13, 2008 - 4:29 AM
NGHTKD
Joined Feb 2, '06
yep thats the guy, clarence.
thats what mine look like & its really easy to do. DIY FTW!
This post has been edited by NGHTKD: Nov 13, 2008 - 4:29 AM
post Nov 13, 2008 - 8:25 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
the empty spot is for the rear fog light...
post Nov 13, 2008 - 1:09 PM
foxcraze
Joined Jul 26, '08
From Fort Bragg, NC
My stockers had 5 bulbs and jdms have 4 slots, which bulb is the fog light bulb? Also my reverse lights dont light up with my jdms but i guess it could be a blown fuse i will check that first
post Nov 15, 2008 - 6:17 AM
trdproven
Joined Aug 2, '05
From Guam
Thats why I used the JDM harness that it came with.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 16, 2008 - 3:38 PM
AnaXyd
Joined Jul 15, '08
From Norway
QUOTE (NGHTKD @ Nov 13, 2008 - 5:29 AM) *
How?
Got mine today, and plugged the fogs in the inner lights. (Not the reverse light) I want the all four light up as brake lights..
post Nov 16, 2008 - 7:30 PM
MercuryFree
Joined Dec 21, '06
From New Zealand
QUOTE (Daftboy @ Nov 14, 2008 - 2:25 AM) *
Erm. The JDM tail lights have 4 sockets, which are (from outside in): Indicator, Brake Light, Brake Light, Reversing Light.
Or at least, that's what my 100% JDM celica has...
Easiest option it to get a hold of the JDM wiring harness tbh, the part number of which is 82181-2B060 smile.gif
This post has been edited by MercuryFree: Nov 16, 2008 - 7:34 PM
post Jan 25, 2010 - 8:12 AM
whatthe
Joined Aug 13, '08
From Australia
Ok a bump.
Ive taken out my usdm harness. And the brake light that is working has three wires coming out. Two from one hole and one from one. Whilst the dead brakelight has one wire in each hole (there are two holes, so two wires). How would one wire this up. Im assuming the two wires from the one hole control the light option of, 1. On 2. Brighter on (when brake is used).
post Jan 25, 2010 - 9:16 AM
trdproven
Joined Aug 2, '05
From Guam
just try to get the jdm harness it makes it easier but if you want to modify theres always a way.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 25, 2010 - 3:48 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
I used the usdm harness and it worked fine. Both of the lights shine for the tail lights.
1999 Celica GT Hatchback
post Jan 26, 2010 - 8:08 AM
whatthe
Joined Aug 13, '08
From Australia
I did a DIY modified the usdm harness so both bulbs do the same. If there is interest i could do a write up. All thanks to my dad.
post Jan 26, 2010 - 12:42 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
i used my usdm harness with my jdm tails and i have the 2 lights in the back, i still have my jdm harness laying around, if you want it shoot me a pm with an offer
2001 Solar yellow Lexus IS300
post Apr 8, 2010 - 2:05 AM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
Just a simple splice of the wire to attach it to something - the inner light wire is not connected to anything at all, so chop it off and connect it to the brake light wire - it's been a while since I did it but I *think* it's the single-colour wire on the outer brake light.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Apr 8, 2010 - 3:31 PM
Tech-Nics
Joined Jun 18, '08
If I'm not mistaken, The JDM and/or EDM rear fog light are standard brake & night time driving lights here in the US. When I got the JDM tails for me and my wife they plugged in with the supplied JDM harness and both lights on each side worked as brake and night driving lights. I think the wiring from inside the car before the harness determines how the brake lights gonna work. I know the USDM tails have the extra outer night time driving marker lights. The JDM tails only have 1 brake light per side and the inner lights before the reverse light are the rear fog lights. I don't know if the rear fog lights are standard or an option and if they are an option then how does the tails work if there is no rear fog light?
Lo-Fi Version Time is now: January 10th, 2025 - 7:43 AM
