> Quick airbag question referring to the ECU
post Nov 13, 2008 - 3:00 PM
Rymaster
Joined Feb 20, '08
From Abingdon, Maryland
okay, so i've had these new airbags sitting around forever and i'm finally going to put them in. I have both airbags and the front 2 senors, however.... do i have to replace the ECU as well? I've heard that you do, and i've heard that you don't have to....
can i just reset it like this (thread link for pic below) and get away without buying a new ecu? or do i have to replace it?
and when people say "center sensor" and "main control module", they are referring to the ECU, correct?
post Nov 14, 2008 - 12:12 AM
1 replace, no you don't have to.
2 yes. The center sensor and main control module is the SRS ECU.
Try clearing the code (it's tricky to do but it does work)
Lo-Fi Version Time is now: January 11th, 2025 - 3:02 PM
