![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 4, '03 From Twin Cities MN Currently Offline Reputation: 2 (100%) ![]() |
I've got a dilemma... My front plate's bolts are falling out of their mounting brackets, and only the far right bolt seems to be the reason why my plate hasn't flew off completely yet. The two middle bolts are barely long enough to fit into the bumper, but the outer bolts are much longer (I haven't removed the plate completely yet- don't have the tools here at work, and I’m also afraid that I might not be able to get the plate to stay on again once it does come all the way off...). I'm assuming that there should be a nut attached to the end of the bold on the outer mounts, but I can't figure out how I’m supposed to get behind the bumper to screw one on? Anyone know what is going on here, or suggestions on how to fix the plate without drilling any new holes?
-------------------- Car #3: 98 Accord LX- purchased 5/06, totaled 8/06
Car #2: 95 Celica GT- purchased 8/03, current daily driver Car #1: 01 Focus ZX3- purchased 5/01, sold 8/03 |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
You can fix the plate by removing it
![]() Enthusiast ![]() ![]() ![]() Joined Nov 21, '05 From Tacoma, WA Currently Offline Reputation: 7 (100%) ![]() |
The two inner bolts should only be long enough to attach the plate to the bracket. The outer two bolts hold the bracket to the bumper. The backing nuts inside the bumper on my car popped out so I used a couple of well nuts to put the bracket back on. I had to drill the holes a little bigger to get the right size well nut in there.
Here's a link: http://www.emhart.com/products/pop/wellnut.asp You can buy them at Lowe's or Home Depot too |
Lo-Fi Version | Time is now: February 19th, 2025 - 11:53 PM |
