How To Convert To A GT-FOUR Front End |
Nov 15, 2008 - 10:33 PM |
A How-To/Guide to convert to a GT-FOUR Front End ------------------------------------------------------------ Intro --------- there are a lot of gt-four front end conversion information spread out across different threads so i figured i'd compile a bunch of information into a single thread. this thread should hopefully answer most gt-four conversion questions. the purpose of this thread is to present all the parts that are needed to doing the conversion and identify the little mods that need to be done for everything to fit properly so you can DIY. basically you will need ALL the parts in the following figures (except those circled in blue) to closer resemble the specs of the gt-four front and allow perfect fitment... however seeing as this will be an expensive project, there are several things that you can do in order to take the most cost-effective route. take note of the numbers in the figures marked in red as it will be later referenced: [1] Front Reinforcement (Crash) Bar You can use the stock crash bar and cut it or use the gt4 crash bar and modify it to fit the stock frame rails. However, the crash bar will not sit properly in the gt-four bumper foam absorber. If you get the st205 crash bar you might as well get the st205 frame rail adapters in order for the crash bar to sit flush inside the foam absorber. If you decide to cut your stock crash bar or modify the gt4 crash bar to fit the stock rails, there will be about a 1.5" gap between the absorber and the crash bar AND 1/2" offset in height. But on the bright side, the gap will not cause the look to appear any different than a stock gt-four.. modified gt4 crash bar on stock rail adapters show that it doesn't align with the bumper & bumper absorber Pros: You save about $300 without having to buy the crash bar (~$100) and frame rail adapters (~$200) without affecting the overall appearance. Cons: If you lightly bump into an object, the bumper will flex until it reaches the end of the 2" gap and stop at the crash bar. This increases the bumpers chance of cracking or damaging. Notes: on modifying your existing crash bar (taken from What's the GT4 Bumper made out of?" : Because that mess is light as heck and kinda flimsy. Or is it just mine? Anyways, I was curious about that and I am also wondering if someone can explain in full detail how to cut the stock Celica impact bar? They said it was in layers. So am I cutting it like sideways? How much? Anybody got pics? My stuff is coming in Thursday or Friday from the paint shop. Also a tab is broken in the top part of where the screw goes into the fender. The guy said I should be alright without that top tab if I just have the part where all the screws go through. Like that lil bar that bolts to the inside bottom inner part of the bumper. I kinda think it will create a gap. Wondering if I should try and fix it with fiber glass and styrofoam (that kind you can mold). Anyways, replies and thoughts are welcome and needed asap if you can give in. Thanks The crash is made up of what I like to refer to as 3 inner chambers. Basically, you're going to cut across the bar, removing the bottom "layer" of the crash bar making it 2/3 of the size it was originally. I don't have any physical pictures, but I just drew this picture for you . As for the bumper, I'm not quite sure what you are referring to, but having just 1 tab broken shouldn't be a problem. The bumper is held on by enough bolts as is, so it should hold just fine. A pic of the finished product (from FS: lots of ST205/ST204 Parts, bumper/headlights/tails/spring/strut/seats) ST204 crash bar already cut to fit ST205 bumper - 25$ + shipping Supplementary Notes: on modifying your existing crash bar (taken from Need help with the gt4 front bumper) i haven't done this since i used an actual gt4 reinforcement bumper... but looking at it, it seems you'll need to cut a straight horizontal line across the bar starting right below the top bolt of the frame rail, and another just above the bottom bolt all the way across. here are two pics for comparison: the pink lines is where you cut. Notes: on modifying a gt4 crash bar to fit on stock frame rails (taken from finished gt4 conversion) the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's. this is how it appears when you compare two ST205 crash bars and have it against the frame rails... as you can see, the bottom is far too forward for the upper threading to fit through... this is how it looks after being cut (using an impact metal sheet cutter): and here it is when bolted on another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect. [2] Bumper to Hood Metal Retainer & Rubber Seal You can use your stock ST/GT metal retainer and rubber seal, and make a few 'bends' to make it fit properly. I did this the first time doing the conversion and it works, it will not appear 100% however so if this doesn't work out for you, you can always bite the bullet and pay the ~$60 to order the gt-four retainer and seal. [3] Fog Lamps If you don't want to get the gt-four fog lamps (which cost ~$200) you need to get the correct bezel type as there is one for fog lamps and one without. If you plan to use the stock gt-four fog lamps, you'll need to use the gt-four crashbar and frame rails in order for the foglamp to align properly iwth the foglight bezel. If you already have a 96-99 celica with foglamps, you may be able to wire the fogs easily using your current fog light wiring. Otherwise, you can find foglight wiring kits at Walmart or other automotive shops for about ~$10-$15 and wire them yourself. I would recommend you wire them to your ignition power so that it will always shut off when you leave your car in case you accidentally leave them on and drain your battery. An alternative solution is to get the fog lamp bezels anyway (without the fog lamps) and put your own 4" fog lamp. There are a number of fog lamp kits out there you can use. Mounting them is another story. You can mount the fogs onto the bezel using a $4 tube of basic household silicone sealant (from a hardware store) and cement glue. Basically glue the fog lamp to the bezel and then fill the surrounding area with silicone. It's very easy and takes about 5 mins plus 15 mins to cure. I have been using my fogs for 2 years now and hasn't fallen off. the pic shows the lamps glued to the bezels and silicone surrounding the lamp and bezel. another option is to create your own bracket. some people on the forum have done this already. Pros: save $250. use any 4" fogs you want. good opportunity to upgrade to 'clear' lens fogs.. Cons: need to do some custom work.. [4] WRC Hood The only difference between the WRC hood and the non-WRC hood is that the WRC hoods have 4 holes that are used to mount the hood spoiler. The hood spoiler doesn't provide any significant benefit except for looks... and it adds 6Gs of downforce to your FWD which is always a bonus! . rumor says the hood spoiler is discontinued but i'm sure that's wrong and your supplier should be able to order them new. Pros: WRC hood makes your car way cooler...you can proudly say you have a wrc hood Cons: you'll need the hood spoiler and that costs ~$175. [5] Hood Insulation The insulation is completely optional. afaik, it's main purpose is to muffle engine noise and helps reduce paint fade. the insulator covers the hood vent which makes your car un-c0ol. Pros: by not getting the insulation it shows off a portion of your engine bay through the hood. Cons: hmmm.. can't think of any. [6] Upper Front Bumper Support Bar The gt-four upper bar is higher in the center than regular ST/GT's. If you decide to get the gt-four support bar it needs to replace the existing one. It bolts in the center and welds on the ends. gt-four upper support bar shown with st205 frame rails and crash bar. image taken from Batman722's thread: painting batman722's gt-4 front end conversion Otherwise, you can use custom spacer brackets like in Malpaso's car... Or you can use long bolts and have the bumper retainer clamped between the head of the bolt and a nut. [7] Hood Latch The original hood latch is able to latch the hood securely however the safety hook is too short. The short safety hook will not allow enough clearance to fit your fingers in between the hood and bumper to pull the lever and release the hook. If you close the hood with an unmodified hood latch, you will not be able to open the hood. There are 3 ways you can go about fixing this: a) The best way is to order the LHD gt-four hood latch as it should be a direct swap. The RHD and LHD latches differ as the hood release cable attaches on different sides so a RHD gt-four latch won't work if you got it from a halfcut. The only problem is the LHD ST205 hood latch can only be ordered in the continental European countries where LHD ST205's were sold. b) The other way is to modify your own. You can extend your safety hook latch an extra 1.0" (Requires some welding). Image courtesy of nics from this thread, with the added dimensions by me. Click here to view the original image. Click here to see an example of Malpaso's modified hood latch. Click here to see an example of Celiquick's modified hood latch. The GT-Four Curse: The common dilemma with this conversion is that people are not closing the hood completely and instead it is the safety hook alone that is holding it down so after going over 40 mph or so the built-up air pressure under the hood would release the hood from the safety hook and smash the hood against the windshield (windscreen). This is due to the safety hook not being extended long enough to make the hood appear that it's not properly latched. When you release the hood, the hood travels up until the safety hook stops it. It should then leave you enough of a gap to fit your fingers and release the safety hook. If the hook isn't extended long enough, you will NOT be able to open the hood and you'll have a difficult time. Be sure that it is long enough so that when you release the hood, you can tell the hood is unlatched. c) The last way to go about it is to bend the safety hook entirely out of the way (you don't really need it). This is a good temporary solution until you get the safety hook extended or until you order the LHD hood latch. Now that the safety hook is no longer being used, it's very obvious to differentiate if the hood is unlatched or not since nothing is holding it down. I still have my safety hook this way since the conversion over 3 years ago and have had the 'curse' happen once... until this past winter (see below) . The aftermath of improper hood latch modification.. It could have been much worse. Luckily the windshield didn't smash. Before After X. Turn Signals The gt-four turn signal connectors are completely different from the ST/GT ones, so that makes the two sockets different from one another. So you'll need to use your stock bulb & sockets but in order for it to work in the gt-four turn signal housing, you need to cut a tiny 2mmx2mm rectangular notch like this: |___| . the stock socket has notches in different positions than the gt4 socket. this mod only takes 2 mins using a utility/X-ACTO knife or any sort of blade. i don't have pics of this but it's a very simple mod. FAQs: 1. Where can I buy the GT-FOUR parts listed above? You can order them from any Toyota dealer that have access to the japanese catalog. Ordinary dealers won't be able to supply you these parts. To get the best price, contact Aaron of PartzNet.com. See this thread for Aaron's contact information. Other common sources to order from are ToyotaWorld.com (it's best to call them) and 1stToyotaParts.com. But please note, all the parts can be obtained from these dealers except for the LHD ST205 hood latch as it can only be ordered from European countries that sold LHD ST205's. 2. How much will it approximately cost all together? It depends on the parts you order. If you order only the mandatory parts, it can cost around $1000 plus shipping. If you get all the extras (ie. fogs, rails, crashbar, retainer, upper support, hood spoiler, insulation, etc etc. it can cost close to $2200 plus shipping. Keep in mind the parts need to be painted as well. In general, the more you money spend on this project, the less custom work is required. 3. Can you break down the cost for each part? Prices for individual parts can be found here: JDM OEM Part Numbers and Prices If it's not listed in that thread, PM me and I will let you know. 4. Can I get the GT-FOUR hood without the bumper? It will work but you will have a 1" gap between the stock bumper and the gt-four hood. 5. Can I get the GT-FOUR bumper without the hood? Yes, but it may not be 100% flush, you cannot use the upper bumper retainer (Part number: 53205-20070) from the GT-Four, but will still need to get the GT-Four frame rails & crash bar, or modify/remove your stock one. 6. Will the bumper bolt on to the stock fenders? Yes. 7. Will it be bad if snow or rain fall in through the center hood grill? All GT-Fours came with a plastic cover mounted between the hood grill and the hood insulation. It catches rain water and directs it to the front where it falls on the radiator improving cooling. However, this weakens the end tank of an oem radiator due to the changes in temperature (expansion and compression particularly in cold weather climate) on the composite material. After 2 years my oem rad developed a crack causing the engine to spew out coolant when it was about -40 degrees. so I purchased a metal radiator (from performanceradiator.com aka USA Radiator). Most people remove this plastic cover as it improves cooling by releasing the hot air trapped in the engine bay. There is no real potential hazard with rain or snow falling through since rain drops and snow flakes will quickly evaporate as it reaches or comes in contact with the header or heat shield. If your car can withstand an engine bay wash, then it should withstand small rain drops or snow falling through. If there's anything else that is missing, please let me know and I will add it. Thanks This post has been edited by azian_advanced: Jul 18, 2015 - 6:47 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Nov 15, 2008 - 10:45 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
This looks thorough! Hopefully I'll one day be able to afford to use this guide. -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Nov 15, 2008 - 10:46 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
STICKIFY this bad boy
Gerald, where did you get your lamps again. I want the ones like yours because they are frosted vs the checker/ auto zone ones where they are clear. -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Nov 15, 2008 - 11:06 PM |
i bought them from a local auto parts store called Princess Auto. my fogs aren't actual fog lamps with exchangeable bulbs but they're meant for mounting on 4x4s for off-road purposes
Nov 15, 2008 - 11:08 PM |
Enthusiast Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) |
wow with that new avatar i didnt noticed it was the famed azian
GREAT info -------------------- BANNED. for life, you moron.
Nov 16, 2008 - 2:12 AM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
everyone in this community will love you forever
now if only someone could do this same thing with hybrid axles... -------------------- |
Nov 16, 2008 - 2:41 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
At last even every noob here knows who is the master of how to articles here
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Nov 16, 2008 - 3:13 AM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
At last even every noob here knows who is the master of how to articles here x2 -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Nov 16, 2008 - 5:46 AM |
Gerald,
Would the latch need to be extended upwards? Is there a plug n play latch replacement from a gt-four that will work? -------------------- 94 Celica GT
Nov 16, 2008 - 6:49 AM |
Gerald, Would the latch need to be extended upwards? Is there a plug n play latch replacement from a gt-four that will work? yes, and yes, the LHD gt-4 latch bolts right on. great post, added to the sticky! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Nov 16, 2008 - 10:46 AM |
Enthusiast Joined Jun 16, '06 From Plantation, FL Currently Offline Reputation: 0 (0%) |
Now I just need to get some money.
Nov 18, 2008 - 3:02 AM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
STICKY!
Nov 18, 2008 - 7:22 AM |
QUOTE great post, added to the sticky! read my post. -------------------- Former Team 5SFTE pro member ;)
Nov 21, 2008 - 5:10 PM |
Gerald, Would the latch need to be extended upwards? Is there a plug n play latch replacement from a gt-four that will work? yes, and yes, the LHD gt-4 latch bolts right on. great post, added to the sticky! where could I buy LHD gt-4 latch? -------------------- 94 Celica GT
Nov 22, 2008 - 4:23 AM |
This is what it looks like I really need:
Hood LHD GT4 Hood Latch or Modify Extend Upwards Bumper Modify St204 crash bar and reuse foam Modify support bar like you and malpaso Seems like thats it? This post has been edited by trdproven: Nov 22, 2008 - 4:26 AM -------------------- 94 Celica GT
Nov 22, 2008 - 8:48 AM |
i don't think you can reuse your stock bumper foam because of the upper grill and the small slit beneath the upper grill on the gt-four bumper.. unless you plan on modifying this yourself..
Nov 22, 2008 - 8:00 PM |
If one was to modify the stock st204 crash bar/reinforcement bar or even the gt4 reinforcement bar, how would that affect mounting the fogs properly?
Nov 23, 2008 - 5:18 AM |
thanks for pointing that out. if you keep your stock crash bar, the gt-four fog light brackets won't directly bolt up but even if you manage to do so, it will be sunk in and sit an inch higher from the fog light bezel. so if you are going to use the gt-four fog lights, you'll need the gt-four crash bar and frame rails to ensure perfect fitment.
otherwise if you decide to modify your stock crashbar or modify the gt4 one, you'll need to design your own fog light bracket, or figure a way to mount the foglight directly to the foglight bezel (which is what i did). -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Nov 23, 2008 - 7:58 AM |
does water get in the hood scoop onto the engine or is there a water bypass?
Nov 23, 2008 - 8:23 AM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
does water get in the hood scoop onto the engine or is there a water bypass? The two scoops at the back drip water into areas with largely nothing in. On a proper gt4, the small scoop feeds into the belt cover and has its own water bypass. The large grill has a plastic guide that causes the water to drop between radiator and exhaust manifold if fitted (or onto the manifold if acelerating). But most people remove that and the hood (bonnet) lining causing water to drip directly onto the manifold. -------------------- Davey
Items for sale |
Lo-Fi Version | Time is now: November 25th, 2024 - 9:57 PM |
