3 Pages V  < 1 2 3 >
> How To Convert To A GT-FOUR Front End
post Feb 2, 2009 - 1:15 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (BloodyStupidDavey @ Nov 23, 2008 - 6:23 AM) *
QUOTE (trdproven @ Nov 23, 2008 - 12:58 PM) *
does water get in the hood scoop onto the engine or is there a water bypass?
The two scoops at the back drip water into areas with largely nothing in. On a proper gt4, the small scoop feeds into the belt cover and has its own water bypass. The large grill has a plastic guide that causes the water to drop between radiator and exhaust manifold if fitted (or onto the manifold if acelerating). But most people remove that and the hood (bonnet) lining causing water to drip directly onto the manifold.
Does this cause any troubles with the manifold? (extreme heating/cooling)
post Feb 2, 2009 - 2:53 PM
azian_advanced
Joined Apr 18, '05
From Calgary
let's just say it's not as bad as driving to the local car wash and washing the engine bay.. or another example is to drive from point a to point b and parking your car outside in -20 degree weather (another example of extreme cooling).
so seeing that the above two examples are perfectly ok, i wouldn't worry about rain falling through the vent.
post Jul 30, 2009 - 12:01 PM
turbochloe
Joined Jul 22, '07
From nj
can i get the measurements of these so i can make it?
post Jul 30, 2009 - 2:24 PM
azian_advanced
Joined Apr 18, '05
From Calgary
that is malpaso (Martin's) car. try PMing him about it.
post Jul 30, 2009 - 5:14 PM
QUOTE (turbochloe @ Jul 30, 2009 - 12:01 PM) *
you could also just use longer bolts and a few body washers. how many/how tall it needs to be will vary a bit depending on how straight your car is.
i used like 3 or 4 body washers for years till i swaped in the gt-4 bumper support.
post Nov 22, 2009 - 3:54 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how much lighter is the gt-four crash bar??
post Nov 22, 2009 - 6:36 AM
Cavegod
Joined Jul 11, '09
From UK
its about the same, the gt crash bar is alloy
post Sep 6, 2010 - 10:51 PM
elco
Joined Sep 6, '10
From usa, tucson, az
Im missing two parts to finish my conversion. Can someone tell me where i can get them. I need the hood latch and the frame rail adapters. Thanks -Will-
post Sep 10, 2010 - 2:36 AM
mak5603
Joined Oct 20, '08
2014 Toyota Rav4 XLE
post Sep 14, 2010 - 1:37 PM
chacha
Joined Dec 29, '05
From So-Cal
PM me a price offer for the frame rails....i have them both, but let me ask my brother if he still wants them...if not, ill sale to you. and i can weld the st205 latch hook with the regular USA base for easy usage...my works great for a price....
This post has been edited by chacha: Sep 14, 2010 - 1:53 PM
post Jun 21, 2015 - 8:41 PM
Celicia
Joined Dec 12, '08
From Washington DC
I hate to post a reply to such an old thread, especially a thread that has been sticky-d. But in regards to not being able to install a GT-FOUR front bumper with a stock GT/ST hood, well that is incorrect as I just installed a GT-FOUR front bumper on a 94 Celica ST with the stock hood. The only thing is, I had to remove the crash the bar, but as noted in this sticky you would have to modify the stock crash bar to fit with the GT-FOUR hood. I did not modify any portion of my car or bumper besides removing the crash bar, and it is actually decently flush. I will post pictures tomorrow.
post Jun 21, 2015 - 11:05 PM
richee3
Joined Jun 29, '08
From Denver
It's not that it doesn't fit, it just doesn't fit properly. The stock hood pushes the center portion of the bumper down, creating a gap near the high beams. Not super noticeable unless you know to look for it.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 22, 2015 - 7:11 AM
Celicia
Joined Dec 12, '08
From Washington DC
QUOTE (richee3 @ Jun 22, 2015 - 12:05 AM) *
I certainly agree with you to an extent richee, but this post suggests that installing the GT-FOUR front bumper only is absolutely out of the question:
"5. Can I get the GT-FOUR bumper without the hood?
No. The hood will hit the bumper before reaching the hood latch since the center of the st205 bumper is higher than stock."
That simply is not the case. The hood is no where near hitting the bumper in my car. I think it's important to have correct information on here as getting a front bumper & hood can be costly, and/or if people just want the front bumper than they can do so.
post Jun 22, 2015 - 2:43 PM
Celicia
Joined Dec 12, '08
From Washington DC
See.
This post has been edited by Celicia: Jun 22, 2015 - 2:52 PM
post Jun 29, 2015 - 1:10 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
post Jun 30, 2015 - 7:23 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
neat!
Id like to do it the opposite way, 205 hood, pre-face bumper.
エキサイティングカーレーシングチーム!
post Jun 30, 2015 - 10:44 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Done that to... Sorta... hahaha
post Jul 11, 2015 - 1:44 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Tigawoods @ Jun 30, 2015 - 8:23 AM) *
neat!
post Jul 18, 2015 - 6:47 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE (Celicia @ Jun 22, 2015 - 7:11 AM) *
Thanks for that feedback.
I've updated the OP with that new bit of information.
post Sep 10, 2015 - 3:02 PM
antoine64
Joined Dec 9, '14
From Juneau, Alaska
[/quote]
the only problem with this is that it looks like the bolt holes don't line up. bottom one is at a different angle. I'm in the middle of figuring this out. How do you get the longer bolts to line up?
also did you have any trouble with mounting the GT-4 bumper retainer bracket on a non-gt-4? my bracket doesn't line up right once I press in the pins on either end.
This post has been edited by antoine64: Sep 10, 2015 - 3:03 PM
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: February 17th, 2025 - 3:55 AM
