> which swap???
post Nov 17, 2008 - 11:50 PM
celica09
Joined Nov 17, '08
From columbia al
ok i got a stock 94 celica with a 7afe engine kindasad.gif its weak really weak and old runnin about 236000 miles so i wanna do a swap but i dont know which one would be best i have researched alot and thought about the diffrant options but out of 3sgte and the 4agze or 7age with little money and not too much experiance wat would be the best and cheapest/ easiest swap for me
post Nov 18, 2008 - 12:01 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
cheapest and easiest, swap in another 7afe. No need to worry about the wire harness and its cheap.
94 Celica gt white (sold)
post Nov 18, 2008 - 12:05 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
By far the best bang for your buck for an ST: 4AGE Blacktop.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 18, 2008 - 6:47 PM
celica09
Joined Nov 17, '08
From columbia al
i would go with another 7afe but i thought about if i turboed it and the rods are very weak and thin but i have done alot of thinking about the 4age but the blacktop is a 20valve right? why a 20 valve over a 16 valve?? would it require more work??
post Nov 18, 2008 - 6:55 PM
Dr_Tweak
Joined Mar 31, '04
It's not any more work than a 16v to swap it, it just makes more power smile.gif
-Doc
post Nov 18, 2008 - 7:00 PM
celica09
Joined Nov 17, '08
From columbia al
hmm sounds good to me so how much mods. am i lookin forwards too for this swap??
post Nov 18, 2008 - 7:44 PM
CelicaST_CALI
Joined Feb 28, '07
depends...look on ebay..
BANNED. for life, you moron.
post Nov 18, 2008 - 10:02 PM
celica09
Joined Nov 17, '08
From columbia al
ok thanks for the help
post Nov 18, 2008 - 10:04 PM
slow94st
Joined Oct 8, '06
From Jersey sHore PA
put a twin charged 4agze in it
3sgte next year i hope
post Nov 18, 2008 - 10:25 PM
celica09
Joined Nov 17, '08
From columbia al
that would be sweet but dont you have to fabricate the 2nd supercharger or do they make twin charged 4agzes???
post Nov 18, 2008 - 10:43 PM
Add45
Joined Sep 1, '08
From STL
i am in the exact same boat as this guy except i know nothing about engine swaps lol
post Nov 18, 2008 - 11:22 PM
celica9110
Joined Feb 6, '08
From charleston, sc
how hard is it to do a 4A swap in our cars?
engine mounts? do i need to modify them?
and will my 7A tranny mount to it?
myspace!!
go FULL THROTTLE or go home
post Nov 19, 2008 - 12:32 AM
celica09
Joined Nov 17, '08
From columbia al
well i have researched and ive seen that all "a" trannys will mate right with all "A" motors but the motor mounts im not too sure ive probly read it but dont remember.. but i need to know wat the easiest way to program the ecu should i get the 4age ecu mated with my wiring harness or should i get a megasquirt?? or get my stock ecu reprogrammed??
post Nov 19, 2008 - 7:38 AM
Add45
Joined Sep 1, '08
From STL
im pretty sure 'A' engines mount no problem
post Nov 19, 2008 - 9:55 AM
celica09
Joined Nov 17, '08
From columbia al
yeah well that works out i think im going to go with the 4age blacktop and turbo it but the thing is i herd hat the 4agze motors came with a 6 speed tranny and i have an automatic how hard would it be to drop a 6 speed maual into my car??
post Nov 19, 2008 - 10:23 AM
celica9110
Joined Feb 6, '08
From charleston, sc
im thinking about swapping the tranny from auto to manual, so maybe once i get the money ill go up to there to the jdm guy lol
and have him swap my auto to manual, bc the 4A i found came w/ a 5sp
soooo ill keep the tranny and use my auto 1 until i get the $$$ and parts
myspace!!
post Nov 19, 2008 - 1:17 PM
celica9110
Joined Feb 6, '08
From charleston, sc
is a 4a swap a rwd swap?
myspace!!
post Nov 19, 2008 - 4:26 PM
celica09
Joined Nov 17, '08
From columbia al
from wat i rad it can be either but i do know that u have to get a fwd tranny of coarse but yeah i have seen fwd and rwd 4ages
post Nov 19, 2008 - 4:37 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE (celica09 @ Nov 18, 2008 - 10:25 PM) *
You would add a custom turbo system to the 4AGZE which is already supercharged. I don't recommend it though. Here are some pics of it actually being done:
http://www.phoenixtuning.com/toyota/swaps/brandon.html
QUOTE (celica9110 @ Nov 18, 2008 - 11:22 PM) *
It swaps right in using either transmission, and use your stock axles. You will need custom wiring, a/c lines, p/s lines, and a little exhaust and intake work.
QUOTE (celica09 @ Nov 19, 2008 - 12:32 AM) *
Just have the wiring converted: http://www.phoenixtuning.com/
QUOTE (celica09 @ Nov 19, 2008 - 9:55 AM) *
The 6-speed from the 4AGE 20v blacktop should bolt right in like any other 4AGE.
QUOTE (celica09 @ Nov 19, 2008 - 4:26 PM) *
In the Celica it's FWD. It can be swapped into some older RWD cars as well, like the AE86.
-Doc
post Nov 19, 2008 - 10:37 PM
celica09
Joined Nov 17, '08
From columbia al
so just to be sure a 7afe would bolt up to a 4age tranny??
Lo-Fi Version Time is now: November 23rd, 2024 - 6:58 PM
