> rpm problem
post Nov 24, 2008 - 2:23 PM
1994toyotaracer
Joined Sep 2, '05
From delaware
hi i am having a problem where when the car is in neutral a rev it up to 3000 and hold it then slowly increase the rpms it jumps from 3150 to 4000 with no pedal effort it also does this at the same rpm when im driving the car under load in a higher gear it jumps like that aswell
post Nov 24, 2008 - 3:10 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well your rpm wires seems like its loose..check your ignitor plug..the rpm wires is the gray one.
Lo-Fi Version Time is now: February 17th, 2025 - 7:41 AM
