> OEM end link part numbers, Help...
post Nov 28, 2008 - 9:40 AM
Jeunesse
Joined Aug 21, '07
From Toronto
anybody knows what the part numbers for the front and rear end links are?
-Derick
"In hoc signo vinces." In this sign thou shalt conquer."
Gone but never forgotten....
post Nov 28, 2008 - 11:42 AM
BURNSJ2
Joined May 14, '07
From las vegas, nv
48820-33010 front, shows to be the same for both sides
48830-20010 rear, shows to be the same for both sides.
post Nov 28, 2008 - 11:45 AM
Jeunesse
Joined Aug 21, '07
From Toronto
thanks BURNS
-Derick
post Nov 28, 2008 - 11:51 AM
BURNSJ2
Joined May 14, '07
From las vegas, nv
no probem man, but theyre not cheap either, catalog says about $80 each
post Nov 28, 2008 - 12:52 PM
azian_advanced
Joined Apr 18, '05
From Calgary
you're better off getting TWOSRUS endlinks.. they're half the cost, much sturdier, and better designed than OEM links..
the pair is about $90 shipped.
post Nov 28, 2008 - 2:00 PM
BURNSJ2
Joined May 14, '07
From las vegas, nv
where do you get those at?
post Nov 28, 2008 - 5:57 PM
Jeunesse
Joined Aug 21, '07
From Toronto
Yea I just realized that too... I called a dealership today and its $110 each for front and $90 each for rear.
-Derick
post Nov 28, 2008 - 6:07 PM
Jeunesse
Joined Aug 21, '07
From Toronto
TwosRUs are only selling the st185 sway bar end links... that should be the one I should be getting, right?
-Derick
post Nov 28, 2008 - 8:02 PM
azian_advanced
Joined Apr 18, '05
From Calgary
yeah the st185 endlinks will work on our 6th gens..
post Nov 28, 2008 - 9:40 PM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
QUOTE (Jeunesse @ Nov 29, 2008 - 12:07 AM) *
I have them installed... no worries at all about that (in pics with suspension techniques sway bars).
post Dec 1, 2008 - 6:26 AM
Jeunesse
Joined Aug 21, '07
From Toronto
Ok... I heard that there are settings for these since these are adjustable, right? One is oversteer and one is understeer. Can somebody shed some light into this for me?
-Derick
post Dec 1, 2008 - 2:51 PM
Jeunesse
Joined Aug 21, '07
From Toronto
bump
-Derick
post Dec 2, 2008 - 6:27 AM
malpaso
Joined Feb 3, '06
About endlinks. It's really easy. Any changes are not needed on them at all. No setting, no adjustment. I have installed them as they were from factory. And everything is fine. That understeer and oversteer question is related to sway bars. Rear sway bar from Suspension techniques manufacturer has two mounting points for endlinks. One is for "understeer" and second "oversteer". Physical explanstion is this:
Thanks to this are all RWD cars "oversteering" when you drive fast through bend and slipping...
And all FWR cars are "understeering" when you drive fast through bend and slipping
Really nice it's explained here (I know it's for game but it's true smile.gif ) or in picture below with relation to ESP
And you may change with this sway bar setting your car is reacting like more oversteering or more understeering...
post Dec 2, 2008 - 6:31 AM
Jeunesse
Joined Aug 21, '07
From Toronto
vote for sticky!!!! thanks Martin.
-Derick
Lo-Fi Version Time is now: November 23rd, 2024 - 12:15 PM
