overheating still, replaced whole cooling system |
Dec 4, 2008 - 7:21 AM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
The one hooked to the gauge cluster? Lower hose is on order will pick it up tomorrow. It is only a pin hole but enough that if you squeeze it it leaks and I doubt it allows the system to hold pressure. Its located next to your lower rad hose, there is a test you can do to see if it is working right. Some water and a multimeter...pretty much doing a continunity check. |
Dec 4, 2008 - 8:21 AM |
Enthusiast Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
Already replaced it.
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Dec 4, 2008 - 5:57 PM |
OK, I see that you listed it as the fan sensor switch. My bad...Was the part bad before you replaced it, or was it just kind of a PM thing?
Lo-Fi Version | Time is now: January 9th, 2025 - 11:37 PM |
