What is LSD? |
What is LSD? |
Dec 4, 2008 - 10:51 PM |
Enthusiast Joined Nov 13, '08 From Indiana Currently Offline Reputation: 0 (0%) |
what are you referring to when you talk about installing LSD in your tranny? what is it?
-------------------- Celica Or Die, check out http://www.redlinemotive.com!
Dec 4, 2008 - 10:56 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
It's a drug.
Dec 4, 2008 - 10:58 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
LSD= Greatness
LSD means Limited Slip Differential. For example the stock 5sfe Celica GT transmission utilizes the S54 OPEN Differential trans. No LSD. Eventhough if you take a peak inside the diff where the axles pop into there is a bar running through the middle of it just like the E153 VLSD trans, the s54 isnt lsd. VLSD what I've got means Viscous Limited Slip Differential. The difference between mine is that the Viscous uses liquids to get the LSD to work, which means it is less aggressive compared to a clutch type lsd. Basically when one wheel spins the other picks up the slack. -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Dec 4, 2008 - 10:59 PM |
It's a drug. how did i know someone was gonna say that? lol...but seriously, when talking transmissions, what is it? -------------------- Celica Or Die, check out http://www.redlinemotive.com!
Dec 4, 2008 - 11:00 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
limited slip differential. It prevents "one wheel" power. In a tranny without lsd, if you spin the wheels, only one side will really do most the spinning. LSD detects wheel spin and puts power to both drive wheels, instead of one.
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
Dec 4, 2008 - 11:07 PM |
ohhhhhh...i see...thanks
Dec 4, 2008 - 11:13 PM |
Enthusiast Joined May 22, '08 From dallas texas Currently Offline Reputation: 11 (100%) |
yes but is it possible to "install" LSD in a transmission or does it pretty much have to come with it (the trans)
also is the e153 w/lsd bolt up to 5s? |
Dec 4, 2008 - 11:23 PM |
You can by a differential to put inside the trans. Easy IMO. Yes the e153 bolts on, but you'll need hybrid axles to run it on our cars.
Dec 4, 2008 - 11:30 PM |
so you could have a s54 with lsd...has anyone with a 5sfte done this or have lsd?
This post has been edited by 97celiman: Dec 4, 2008 - 11:54 PM |
Dec 4, 2008 - 11:45 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
came in standard SS-III (98+ or earlier version aswell?) gearbox, TRD also make a machnical one which is available for non SS suspension (helycal L.S.D.)
Dec 4, 2008 - 11:55 PM |
I forgot who, but someone used the mr2 spyder's differential in their s54.
Dec 5, 2008 - 4:48 AM |
Enthusiast Joined Oct 10, '07 From Sunrise Florida Currently Offline Reputation: 0 (0%) |
i was told that my car has lsd when i bought it n i thought he was mistaking. is there any way i could make sure? do i have to go drive through a lake and see if i hydroplane?
This post has been edited by bslik: Dec 5, 2008 - 4:49 AM |
Dec 5, 2008 - 5:39 AM |
Enthusiast Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
What does the picture have to refer to the drug? -------------------- |
Dec 5, 2008 - 11:01 AM |
i was told that my car has lsd when i bought it n i thought he was mistaking. is there any way i could make sure? do i have to go drive through a lake and see if i hydroplane? hydroplaning has nothing to do with lsd. One way you can tell is put your car in neutral and jack your car up and have both tires off the ground. Spin one tire and see if the other tire spins the same direction as the one you are spining. If it spins the same way it has lsd. If it spins opposite it doesnt. -------------------- 98 Celica gt red- totaled deer
Dec 5, 2008 - 11:03 AM |
^ that does not always hold true
Dec 5, 2008 - 11:06 AM |
Yeah I know, but its one way you can kind of tell.
Dec 5, 2008 - 11:23 AM |
It's totally unreliable. That's no way to determine whether you have LSD or not.
Dec 5, 2008 - 11:27 AM |
okay fine. Pull your axles and peak in there. With the stock s54 trans you will see a bar runnning through the diff. That means you don't have lsd. If you peak through it and the bar is removed and you can totally see through it, you might have an after market lsd. If you have an e153 trans and you see a bar running through it you have lsd. VLSD.
Dec 5, 2008 - 5:17 PM |
What does the picture have to refer to the drug? It doesn't, it just shows how I feel about such a common-sense question being asked. |
Dec 6, 2008 - 7:21 AM |
Enthusiast Joined Apr 18, '08 From Oakland, bay area, California Currently Offline Reputation: 1 (100%) |
Lo-Fi Version | Time is now: November 26th, 2024 - 10:45 PM |
