> is this set up good?, looking for this set up b4 i get it in a few months
post Dec 5, 2008 - 8:47 AM
celica9110
Joined Feb 6, '08
From charleston, sc
megan springs: front-1.6"
rear-1.5"
kyb gr2 shocks
suspension techniques front and rear sway bars
cusco front strut bar
myspace!!
go FULL THROTTLE or go home
post Dec 5, 2008 - 9:27 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Never seen anyone use megan springs, but with that drop I don't know if I'd use them. The Tein S-techs do 1.4 front .9 rear. Its like that to give you an even stance. If the megans are 1.6 front and 1.5 rear you aren't going to get an even drop, and it will look like crap.
Everything else is fine.
This post has been edited by 95CelicaST: Dec 5, 2008 - 9:27 AM
**** Photobucket
post Dec 5, 2008 - 10:03 AM
celica9110
Joined Feb 6, '08
From charleston, sc
it was the lowest, any1 using the TEINS? id like a pic
myspace!!
post Dec 5, 2008 - 10:05 AM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
QUOTE (95CelicaST @ Dec 5, 2008 - 10:27 AM) *
they aren't going to look like crap
eibach sportlines are 1.5" f and 1.5"r and they look really good, look at presure2's car
post Dec 5, 2008 - 10:07 AM
celica9110
Joined Feb 6, '08
From charleston, sc
you guys are really putting in input pretty quick...keep it coming
GREATLY appreciated
myspace!!
post Dec 5, 2008 - 10:09 AM
Helix
Joined Apr 17, '07
From Greece
post Dec 5, 2008 - 10:12 AM
celica9110
Joined Feb 6, '08
From charleston, sc
QUOTE (Helix @ Dec 5, 2008 - 10:09 AM) *
can u see a major difference between stock and the new springs?
cuz it still looks a little high
i kinda like the eibach springs =]
myspace!!
post Dec 5, 2008 - 10:28 AM
Promasta
Joined Oct 2, '07
tanabe df210 are supposed to be very good and are made in japan
low drop and 3.1 f/ 2.8r spring rates
coneyre
Joined Dec 2, '08
From Ireland
I would probably go for the eibach springs. I was thinking of getting a set soon myself!
post Dec 5, 2008 - 11:20 AM
95CelicaST
Joined Feb 5, '05
QUOTE (Promasta @ Dec 5, 2008 - 7:28 AM) *
those arent spring rates. spring rate is the amount of weight needed to compress a spring.
almost everyone on here that has aftermarket springs has the s-tech/ gr2 combo. Eibachs and other springs with an even drop amount are going to make the back end look like its sagging. I had eibach sportlines and coomer ended up cutting a coil out of each front one to even out the drop... which was a bad thing to do.
op, if you want to be able to play with the drop go buy a set of ground control coilovers and the gr2 struts. i had that seup on my first celica and loved it. you can change it up from between 1" and 4".
**** Photobucket
post Dec 5, 2008 - 11:25 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
QUOTE (celica9110 @ Dec 5, 2008 - 7:47 AM) *
rear-1.5"
kyb gr2 shocks
This tells me he is not after looks. He is after performance. I say its a good set-up, but you should upgrade your endlinks to st185 ones and get some adjustable camber plates. What helps out a lot too is a rear strut bar.
94 Celica gt white (sold)
post Dec 5, 2008 - 11:30 AM
coneyre
Joined Dec 2, '08
From Ireland
QUOTE (95CelicaST @ Dec 5, 2008 - 11:20 AM) *
I was going to go for the koni yellow and eibach set up. Do you think the s-tech/gr2 set is better?
post Dec 5, 2008 - 11:38 AM
95CelicaST
Joined Feb 5, '05
if you were truly into performance you wouldnt buy springs.
op, to answer your question, koni yellows and s-techs would be a great daily driver setup.
This post has been edited by 95CelicaST: Dec 5, 2008 - 11:40 AM
**** Photobucket
post Dec 5, 2008 - 11:44 AM
coneyre
Joined Dec 2, '08
From Ireland
QUOTE (95CelicaST @ Dec 5, 2008 - 11:38 AM) *
Well im not looking for high performance sport suspension. Im looking for more of a smother ride more comfortable. The roads in ireland arent the best, there is alot of bumps and crap on the road and at the moment my cars bouncing all over the place.
What do you think?
post Dec 5, 2008 - 11:48 AM
Promasta
Joined Oct 2, '07
um yes those are the spring rates, measured in kg/mm
post Dec 5, 2008 - 12:03 PM
95CelicaST
Joined Feb 5, '05
ive never seen spring rates listed like that. coilovers go by 6K, 8K, etc.
**** Photobucket
post Dec 5, 2008 - 1:39 PM
celica9110
Joined Feb 6, '08
From charleston, sc
so im going to still get the basic set up, but im stuck between the teins and the eibach
myspace!!
post Dec 5, 2008 - 1:47 PM
95CelicaST
Joined Feb 5, '05
go look through the members gallery or just search for s-techs and look at the stance. my vote is for them.
**** Photobucket
post Dec 5, 2008 - 2:48 PM
hockeyplyr24
Joined Dec 22, '04
From O'fallon, MO
i have tein s-techs and the kyb gr2 struts i love the stance and how the car rides, perfect drop
post Dec 5, 2008 - 3:37 PM
mikew04
Joined Feb 19, '04
From austin tx
Eibach sportlines don't give an uneven looking drop. It looks great with them; I've gotten many compliments. On rough roads however, you're not going to have the most comfortable ride.
Lo-Fi Version Time is now: November 23rd, 2024 - 2:32 PM
