> Lug Locks
post Jan 11, 2003 - 1:42 AM
magik06
Joined Nov 20, '02
I have lost the key to my lug locks .Does anyone know how to get them off now. What do i need to buy
post Jan 11, 2003 - 3:15 AM
What kind of lugs do you have? You might be better off contacting the lug manufacturer or retailer if you can find them.
post Jan 11, 2003 - 5:32 AM
0Re0
Joined Nov 13, '02
From Hawaii
That happened to me too...You can go with what coomer says or you can just pound a socket in and twist it out. biggrin.gif
post Jan 19, 2003 - 4:45 AM
0Re0
Joined Nov 13, '02
From Hawaii
Get the Locking Lug Nut Removal Socket.
user posted imageuser posted image
It Removes locking lug nuts and locking hubcaps on most vehicles. Updated set includes new turbo lugnut socket to easily remove damaged 3/4", 13/16", 19mm and 21mm lugnuts. Tapered swirl in socket bites into damaged lugnut for quick removal. Removed lugnut may be easily tapped loose from turbo socket. Set is intended for hand use only, except for turbo lugnut socket, which should be used with an impact wrench.
You can get it at http://Snapon.com
or try other brand that makes it. Good luck!
This post has been edited by 0Re0: Jan 19, 2003 - 4:46 AM
post Jan 19, 2003 - 5:01 AM
0Re0
Joined Nov 13, '02
From Hawaii
QUOTE (0Re0 @ Jan 19 2003, 02:45 AM)
And don't go around stealing other peoples rims! L biggrin.gif L!
post Jan 19, 2003 - 6:12 PM
jontechie
Joined Oct 25, '02
From London- England
QUOTE (0Re0 @ Jan 19 2003, 03:01 AM)
You forgot to mention snapon give you a free set of rims free with every purchase.....
post Jan 19, 2003 - 11:57 PM
marcusk
Joined Dec 22, '02
From South Sioux City Nebraska
doesnt that tool defeat the purpose of lug locks?
0Re0
Joined Nov 13, '02
From Hawaii
QUOTE (jontechie @ Jan 19 2003, 04:12 PM)
post Jan 20, 2003 - 12:35 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
This happened to me a while back... I just took it to a friend that's a machanic and he used a torque socket to get them off. worked fine
Lo-Fi Version Time is now: February 17th, 2025 - 1:29 PM
