gauges install? what ones?, hmmm? |
Dec 9, 2008 - 2:22 AM |
Enthusiast Joined Oct 10, '08 From sweet home, OR Currently Offline Reputation: 3 (100%) |
i found some gauges but im wondering what to get i found.
a volt gauge a vacuum gauge a water temp gauge a oil temp gauge and a oil pressure gauge my question is how hard is it to install? idk what i can get i have a non turbo 5sfe in my 94 gt i have a short ram tho.. i only need and can afford 3. any help? This post has been edited by terbear4god4life: Dec 9, 2008 - 2:36 AM -------------------- |
Dec 9, 2008 - 3:32 AM |
Enthusiast Joined Apr 18, '08 From Oakland, bay area, California Currently Offline Reputation: 1 (100%) |
i dont think you need gauges for a nonturbo car.
Dec 9, 2008 - 3:38 AM |
Enthusiast Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
Oil pressure and Oil temp are the most important gauges to have on ANY car....the standard "Oil light" is a waste of time as by the time its come on its too late, the damage will have been done.
Although the more gauges you have, the more you worry about what they are monitoring and there is more to distract you from the road ahead which is far more important than any gauge. Unfortunately the Oil temp/pressure gauges are the most difficult to install as you`ll need to fir a take off plate or find somehwere in the engine to mount the sensors. Water temp is also a good one to have....voltage and vacuume forget about..not worth monitoring on a non turbo car. -------------------- |
Dec 9, 2008 - 9:33 AM |
oil pressure isnt hard at all. the sensor they give u can be plugged into an existing hole on the right frontside of the block where a oil sensor is plugged in. take that out and screw in the new one. thats what i did, the only thing is that the red oil light on the left hand side of your gauge cluster will be on all the time
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Dec 9, 2008 - 9:42 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
oil pressure isnt hard at all. the sensor they give u can be plugged into an existing hole on the right frontside of the block where a oil sensor is plugged in. take that out and screw in the new one. thats what i did, the only thing is that the red oil light on the left hand side of your gauge cluster will be on all the time You were intended to use a Tee so that both of the senders would be installed at the same place. -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Dec 9, 2008 - 12:23 PM |
basically i want 2 gauges i was thinking a volt and something else whats the easiest to install?
Dec 9, 2008 - 4:16 PM |
oil pressure isnt hard at all. the sensor they give u can be plugged into an existing hole on the right frontside of the block where a oil sensor is plugged in. take that out and screw in the new one. thats what i did, the only thing is that the red oil light on the left hand side of your gauge cluster will be on all the time You were intended to use a Tee so that both of the senders would be installed at the same place. this is true. i did not have one at the time. my original plan was to use the oil sandwich plate technique -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Lo-Fi Version | Time is now: November 27th, 2024 - 9:00 AM |
