Where can I get H1 Connectors |
Dec 13, 2008 - 3:36 AM |
Anticipating my projectors to come in. Where can I get the H1 connectors so that I can connect them to my 9006. I'm using HID bulbs as well. Any sites?
Dec 13, 2008 - 6:15 AM |
nvm.. i thought you just needed to wire the projectors with the 9006 connectors.
This post has been edited by azian_advanced: Dec 13, 2008 - 6:22 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 13, 2008 - 6:39 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
Have you try eBay?
-------------------- 98% completion --- aaRon |
Dec 13, 2008 - 8:26 AM |
I was thinking of going from 9006 to custom H1 connector to the HID bulb, unless the HID bulb H1, can just mount up straight to the 9006.
Dec 14, 2008 - 12:24 AM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
ok...
projectors with HALOGEN H1 bulbs go to auto parts store, get an H3 (no typo) connector, and use that. one end is the H3 harness type (3 prongs, but you only need to use 2) and the other is open pigtails - just tin & push into your stock 9006 connector on the car side (so you may always go back to stock) or cut and solder them fast for a permanite connection projectors with HID H1 bulbs MOST all hid kits i have seen, the ballast plugs DIRECTLY and PERFECTLY into the 9006 connector on the car, so NOTHING more is needed. if you need any pictures, i can take several of both setups so you know exactly what you are getting into, but the HALOGEN bulbs i already did a write up back when i first got my projectors. both ways, hid or halogen, its a piece of cake - especially for someone like you (from the impressions i got from you over the past while) -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Dec 14, 2008 - 12:30 AM |
edit: if you need H3 connectors for halogen bulbs, and are unable to locate them, let me know, i can pick up a pair here for well under $10 and mail them to you
Dec 14, 2008 - 12:46 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
QUOTE projectors with HID H1 bulbs MOST all hid kits i have seen, the ballast plugs DIRECTLY and PERFECTLY into the 9006 connector on the car, so NOTHING more is needed. I have SS-III connectors for my projectors, so if I got HIDs they will connect straight up wont they? -------------------- |
Dec 14, 2008 - 3:12 AM |
ok... projectors with HALOGEN H1 bulbs go to auto parts store, get an H3 (no typo) connector, and use that. one end is the H3 harness type (3 prongs, but you only need to use 2) and the other is open pigtails - just tin & push into your stock 9006 connector on the car side (so you may always go back to stock) or cut and solder them fast for a permanite connection projectors with HID H1 bulbs MOST all hid kits i have seen, the ballast plugs DIRECTLY and PERFECTLY into the 9006 connector on the car, so NOTHING more is needed. if you need any pictures, i can take several of both setups so you know exactly what you are getting into, but the HALOGEN bulbs i already did a write up back when i first got my projectors. both ways, hid or halogen, its a piece of cake - especially for someone like you (from the impressions i got from you over the past while) Thats what I was thinking, if I buy H1 HID bulbs, it will directly hook up to my 9006 harness and then have the H4 connector at the end. Is this true? -------------------- 94 Celica GT
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:48 PM |
