Someone posted this on mr2oc and I though I would pass it along. It basically states how and why injection works, as well as the meth content of some of the popular washer fluids.
Its a good read for anyone thinking about setting this up on their car. http://www.labontemotorsports.com/ontrack/WM101.pdf -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
good read...looking forward to picking up a water/meth kit for my car and experimenting with it
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
once again lagos, you provide us with the bread we need!! so should i wait to dyno tune my car unitl i get this water meth injection kit? i was hoping to get it dyno tuned soon after i bring it back from GA.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) ![]() |
once again lagos, you provide us with the bread we need!! so should i wait to dyno tune my car unitl i get this water meth injection kit? i was hoping to get it dyno tuned soon after i bring it back from GA. You can go either way with it, but I personally dont like the idea of relying on the meth to go outside the limits of your injectors. The water/meth injection is a great tool and is almost becoming a must on any turbo vechile for its "intercooling" effect and its abilty to decrease the chances of knock/preignition. You dont HAVE to tune the water/meth injection to see gains from it, as gains are seen from its intercooling effect. Another benfit of the Water/meth inection is the abilty to run more boost as the water/meth injections acts as race gas during injection. Califcarm over on Mr2oc.com was only able to hit about 17 on 91 octane, but with the water/meth injection, he was able to run 20psi. But there are of course more gains to be had by tunning the water/meth injection by running a "leaner (12.0-12.5)" AF ration, more ignition advance, and more boost to tune for. The only problem with doing this is, what happens when you pump fails, or the nozzle gets clogged, etc. You WILL blow you motor if tuned for high boost with added igntion advance, and a lean 12.0-12.5 AF, if you have injection failure. What will you be tuning this with, and on what engine? --------------------
Jim, you learned a lot!
![]() Btw, having to tune for meth or not all depends on how big your nozzle size is. Most of us use a 3-5gph nozzle, and that pretty much requires no tuning. However Califcarm is injecting somewhere around 1400cc worth of alcohol, so on his setup he does need to take out a lot of fuel to see the benefits. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) ![]() |
Right now I would like to have some alcohol injection.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
yeah i plan on running water/meth. mostly water though, knock knock knock, whos there? no one, i'm running water injection.
yeah i plan on running water/meth. mostly water though, knock knock knock, whos there? no one, i'm running water injection. Thank You, Thank You, hes here all week ladies and gentlemen! -------------------- 15PSI - 30MPG - Megasquirt Tuned
once again lagos, you provide us with the bread we need!! so should i wait to dyno tune my car unitl i get this water meth injection kit? i was hoping to get it dyno tuned soon after i bring it back from GA. You can go either way with it, but I personally dont like the idea of relying on the meth to go outside the limits of your injectors. The water/meth injection is a great tool and is almost becoming a must on any turbo vechile for its "intercooling" effect and its abilty to decrease the chances of knock/preignition. You dont HAVE to tune the water/meth injection to see gains from it, as gains are seen from its intercooling effect. Another benfit of the Water/meth inection is the abilty to run more boost as the water/meth injections acts as race gas during injection. Califcarm over on Mr2oc.com was only able to hit about 17 on 91 octane, but with the water/meth injection, he was able to run 20psi. But there are of course more gains to be had by tunning the water/meth injection by running a "leaner (12.0-12.5)" AF ration, more ignition advance, and more boost to tune for. The only problem with doing this is, what happens when you pump fails, or the nozzle gets clogged, etc. You WILL blow you motor if tuned for high boost with added igntion advance, and a lean 12.0-12.5 AF, if you have injection failure. What will you be tuning this with, and on what engine? that makes sense! i want to be on the safe side and tuning lean is something i have been wanting to stay away from. im willing to loose a couple hp for that. i will be tuning this with a greddy emanage blue on a 4th gen with upgraded turbo yeah i plan on running water/meth. mostly water though, knock knock knock, whos there? no one, i'm running water injection. Thank You, Thank You, hes here all week ladies and gentlemen! you guys are awesome lol -------------------- |
Lo-Fi Version | Time is now: February 17th, 2025 - 6:47 PM |
