> greddy emanage blue, anyone running one on a 3s-gte
post Dec 19, 2008 - 1:45 PM
darranst205
Joined Jun 8, '08
From kerry ireland
Ok i have a greddy emanage blue and i entend on fitting it over the christmass to my gt4(3sgte)
what i want to know is, is there anyone running one perferable in a 3sgte
im goin getting it maped on rolling road but are they any good or a waste of time and money iv heard alot of storys good and bad but never off anyone running or had run one in there cars
any last words before i go for it
post Dec 19, 2008 - 2:02 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
mr pittfirefighter had this to say in a topic i read just this morning
copy pasted from this thread http://www.6gc.net/forums/index.php?showtopic=64286
**** important info on the greddy e-manage****
this thing is not made for the 3sgte... it causes nothing but trouble for it. I recently spoke with Dr. Tweak and he says to stay away as well. Not only is it built poorly for a Toyota engine (it can't interpret some of the ignition signals) but Greddy is also bankrupt so getting help for this thing is nearly impossible... stay away and you will be happy wink.gif
This post has been edited by boosted95: Dec 19, 2008 - 2:06 PM
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
post Dec 19, 2008 - 2:19 PM
darranst205
Joined Jun 8, '08
From kerry ireland
Ya i read that too
but iv also read about ppl saying they were good on other modles but never came accros anyone with first hand experance on a 3sgte is all "i was told by ...."
who is that dr tweek anyway has he first hand experance it says there built bad for 3sgte but is he saying there ok for other cars or greddy stuff is crap ??
post Dec 19, 2008 - 2:35 PM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
QUOTE (darranst205 @ Dec 19, 2008 - 7:19 PM) *
Ya i read that too
dr. tweak has alot of firsthand experience with 3sgte's and other forced induction engines/ a master of wiring for swaps and you can see his work on http://www.southerncarcustoms.com/GS_Projects.htm ...clicky that link
id trust tweak until proven wrong...
post Dec 19, 2008 - 3:01 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i have heard great things about the e-manage with other vehichles... other than the fact that they are bankrupt and support for them is dwindling.... the 3sgte and toyota engines specifically use an ignition setup that is very hard for the e-manage to interpret.... there has been a lot of success using the e-manage without the ignition harness...
another thiing... i was specifically referring to the generation 2 engine code of 3sgte... not the third gen that you have... i am not well informed on the 3rd gen cause there were several differences between the two including switching from MAF to MAP
This post has been edited by pittfirefighter: Dec 19, 2008 - 3:06 PM
Breaking Axles...
post Dec 19, 2008 - 3:17 PM
darranst205
Joined Jun 8, '08
From kerry ireland
ok thank ye very much i guess i should have said it was a 3 the main thing i want is to get the fuleing right without goin stand alone cant afford it
my car is a jap import and ment to be running 100ron i think but even running 99ron it has a nasty habbit of blackning the plugs and at 100euro a set its a set
i have the e manage thats the only reason id like to fit it but iv got good advice here so far so im taken everything into account
This post has been edited by darranst205: Dec 19, 2008 - 3:19 PM
post Dec 20, 2008 - 2:48 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
@#$%* mad.gif im running an emanage blue in my setup, but when i did the research i never heard that it was bad for toyota... also doc is aware of me running this setup. i think he would have forewarned me? do you have any additional info about the bad match between the emanage and 3sgte?
post Dec 20, 2008 - 3:18 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
please refer to my other topic for a reply to this post... your 4th gen won't have the problems that a 1st and 2nd gen will... 4th gen uses a different ignition system altogether...
Breaking Axles...
post Dec 20, 2008 - 11:53 AM
darranst205
Joined Jun 8, '08
From kerry ireland
QUOTE (pittfirefighter @ Dec 20, 2008 - 3:18 AM) *
so ur saying its worth given it a go anyway on my car but yes or no on the ignition harness
post Dec 20, 2008 - 3:49 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i believe that its the same style ignition as the 1st and 2nd gen... i am not sure about this... someone else needs to verify this.... you might want to check at alltrac.net... they have a lot more information about the e-manage and 3sgte especially 3rd gen
Breaking Axles...
post Dec 20, 2008 - 7:16 PM
darranst205
Joined Jun 8, '08
From kerry ireland
aright sound for that il stick up a post and let ye know what i do anyway
Lo-Fi Version Time is now: November 24th, 2024 - 2:45 PM
