> Apexi AVCR, Just a quick question
post Dec 20, 2008 - 9:46 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
I just bought a secondhand Avcr from off a guy, and oddly enough, the connecting end of the actual boost solenoid....umm, i have no clue where it connects too...the connection def didnt come like that to begin with, but anywho, anybody who is using the AVCR have some insight as to where it connects too?
(\__/)
post Dec 21, 2008 - 12:42 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
well are you running an external wastegate or internal wastegate??
there's two connections on the boost solenoid itself - one is in and one is out... there are also three ports on the solenoid... we need more info on your setup...
i had a tial external wastegate, it hooks up as follows:
the vac line (i used the original at the turbo that went to my internal wastegate) was T'ed, one side to the input on the apexi boost solenoid, one to the bottom half of the Tial wastegate, the output of the Apexi boost solenoid then went to the top of the tial wastegate
that was my setup but we need to know more about yours
EDIT: i also just want to mention that mine is for sale: great condition, including main screen, full harness, boost solenoid, and vac/boost sensor, this thing is amazing... if you don't know everything it can do... please look it up... definitely worth the money, only selling mine because i now have a stand-alone EMS... PM me... it will be in the for sale section soon
This post has been edited by pittfirefighter: Dec 21, 2008 - 12:45 AM
Breaking Axles...
post Dec 21, 2008 - 6:21 AM
3WayStunna
Joined Jun 25, '06
Sorry but i did a poor job explaining my point in the first post...what i was really talking about, was the electrical connection on the boost solenoid itself. Anywho, the the guy i bought the unit from, for some reason or another, had the normal electrical connecter "diked off", and and in its place two, prong connectors (female ends). I was just curious as to where it is suppose to connect...
youll see what im talking about in the first pic
and in the second, is the connector that i "THINK" it is suppose to connect too...and if so, what wires would need to be hooked up to where? And btw, it is the only connector on the main harness that isnt hooked up to anything...everything else is fine...
This post has been edited by 3WayStunna: Dec 21, 2008 - 6:24 AM
(\__/)
post Dec 21, 2008 - 10:17 AM
http://www.apexi-usa.com/pdfInstallation/45.pdf
Lo-Fi Version Time is now: February 13th, 2025 - 12:24 PM
