2 Pages V  < 1 2
> in process of installing and tuning SAFC2, :)
post Oct 8, 2003 - 1:20 AM
RedSunCelica
From San Diego CA
Ok here are the settings hopefully i copied them correctly.
settings i like are
1000 - 0%
2000 - 0%
3000 - 1%
4000 - 2%
5000 - 5%
6000 - 8%
7000 - 9%
8000 - 9%
running HI
1000 - +5
2000 - +7
3000 - +7
4000 - +5
5000 - +9
6000 - -2
7000 - 0
8000 - +3
low
1k-8k 3%
post Oct 8, 2003 - 4:23 AM
edo17982
Joined Dec 21, '02
From Italy
I think that with thos setting you're still running too rich.
post Oct 8, 2003 - 11:25 AM
ghostdog
From ny to philly
they seem a bit rich tho. I am using modified settings from 97sccelica:
lo
-2
-6
-8
-9
-9
-12
-12
-13
-13
-3
hi
-4
-5
-6
-9
-9
-15
-16
-17
-18
-3
thr points
30 and 70%
post Oct 8, 2003 - 11:56 AM
Kwanza
Joined Apr 8, '03
From NorCal
That's wayy too rich...I'm surprised your check light isn't on and your engine's not coughing and choking...heh
Here's mine...
Note: My Ne Settings are changed to take maximize control over when and how much corrections are made throughout the powerband...
Ne:
1000
2000
3000
4000
4500
5000
5500
6500
Lo:
-6
-9
-12
-13
-14
-11
-9
-5
Hi:
-4
-8
-13
-15
-16
-12
-10
-6
Much more lean and agressive than most would dare...;]
post Oct 8, 2003 - 1:02 PM
FallenHero
Joined Dec 26, '02
From Alabama
Yes, but didn't he dyno his car to get those settings? Also, need I remind everyone of what speedtoe said about judging air\fuel based on a O2 sensor?
Jon
post Oct 8, 2003 - 1:33 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (FallenHero @ Oct 8, 2003 - 11:02 AM)
I would agree with that...but I'm running these not just off of O2 readings, but also slightly off of my old dyno settings... It was re-set after the installtion to zero everything out again, but from memory... my old settings are pretty close.
post Oct 8, 2003 - 6:18 PM
edo17982
Joined Dec 21, '02
From Italy
Here are my settings:
RPMs: 1000 1600 2000 2400 3000 3600 4200 4800 5400 6000 6200 6600
THR: Lo 30% Hi 70%
Fuel Pressure: IDLE 37PSI, WOT 52PSI
Hi settings: -8 -7 -7 -7 -8 -8 -9 -10 -10 -11 -12 -14
Lo settings: -10 -5 0 +1 +2 +3 +4 +5 +6 +7 +8 +8
post Oct 8, 2003 - 7:46 PM
RedSunCelica
From San Diego CA
well i guess this weekend ill be trying out all those settings. hopefully my friend will let me use his dyno to see the differences.
post Oct 8, 2003 - 10:01 PM
Exile04
Joined Aug 20, '03
From Seattle, Washington
WHat exactly does this thing do and does it help speed up my car???
post Oct 9, 2003 - 12:12 AM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (edo17982 @ Oct 8, 2003 - 4:18 PM)
How'd you change the rpms? I mean...mine only changes by the 500'ths... like 1000-1500-2000 etc... can you do that on the SAFC2?
post Oct 9, 2003 - 5:22 AM
edo17982
Joined Dec 21, '02
From Italy
Yes, the SAFC2 let you to change RPMs in 200 increments and allow 12 instead of 8 settings wink.gif wink.gif wink.gif
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 25th, 2024 - 3:41 AM
