Oil Leak ** NEW UPDATE** ITS OFF, ITS OFF |
Dec 25, 2008 - 9:41 AM |
not enough autox haha
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Dec 29, 2008 - 7:09 PM |
Enthusiast Joined Aug 10, '08 From Raleigh, NC Currently Offline Reputation: 0 (0%) |
Im a Toyota Expert Certified tech, 5S-FE's are bad for distributor o-rings leaking. It doesnt look like they sealed the valve cover gasket right either, get a Toyota VC gasket, remove clean and reseal the half moon seals (at both ends of the exhaust cam) and put some sealant in the corners of the end caps on the intake cam also. looks like your power steering pump is a whole different leak. But yeah, 100% percent of the time if you have oil dripping off the intake manifold, the valve cover is leaking, trust me i do this every day.
-------------------- Trust me, I do this every day |
Dec 29, 2008 - 7:18 PM |
thanks! i will have to check those out
Jan 2, 2009 - 1:44 PM |
well right now i am taking off the oil pan.
but i am stuck at the motor mount part. i needed to take a break before i start that. i need to be mentally prepared for it haha. the shop that i took it to called on tuesday and said that it was the oil pan and that i have a steering fluid leak too. they said it would be $250 to change. i was like screw that so i took it from them and started to do it myself. i just need to take off the crossmember and the stiffener plate rear of the oil pan. after that i will take a look at the pan seals it is sealed with an actual rubber gasket and not FIPG or RTV sealant. -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 2, 2009 - 2:19 PM |
Enthusiast Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
This post has been edited by samir0189: Jan 28, 2009 - 2:49 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Jan 2, 2009 - 2:52 PM |
Thats probably why its leaking then, mike. They used junk aftermarket gaskets, and then try to blame it on you somehow.
First it was the headgasket, then the timing belt, and now this... all because they used cheap **** when rebuilding the motor. I honestly cant believe that a shop would be so dishonest as to try to bill you for a leaking gasket on a motor they just rebuild less then a year ago. When you reseal it, make sure you use actual FIPG from the dealer. Its a lot thicker then normal rtv. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 2, 2009 - 4:07 PM |
kk will do. i will have to pick some up from toyota. im held up right now because my brain wont let me take out the rear motor mount so many bad memories with that
Jan 2, 2009 - 4:14 PM |
im going to get some now actually, parts dept. is open still
Jan 2, 2009 - 7:49 PM |
so it is off.
i took it off and the gasket fell apart, it came off into pieces. there where 2 area's where it seems that there could have been a leak. i picked up some FIPG. i cleaned all the org. gasket residue offf i am sanding the oil pan down and repainting it. then i will put everything back together to see if it is fixed -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 2, 2009 - 8:07 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
hopefully thats the culprit...what a PITA...hope you get it all back together and it fixes it mike....f-in 5s...after all this you shoulda just droped a 3s in!! lol
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jan 2, 2009 - 8:37 PM |
i hope its worth it
im cleaning it now and am going to paint it, do a couple coats and then leave it to dry over night. tomorrow will be a good day. i am picking something up. im not sure if i should put it on, or wait until i fix this problem hrmmmm -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 2, 2009 - 8:39 PM |
turbo?
Jan 2, 2009 - 8:47 PM |
Id say you found the problem. Damn those cheap aftermarket gaskets. You figure they couldn't manage to mess up something made out of rubber, but they always find away. Aftermarket = junk. Edit: actually i bet you thats one of those cork or paper gaskets they love to use. turbo shocker sticker? fixed This post has been edited by lagos: Jan 2, 2009 - 8:50 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 2, 2009 - 8:52 PM |
Jan 2, 2009 - 9:55 PM |
i actually took it off the other day a$$holes haha
turbo. i dunno -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 4, 2009 - 1:14 AM |
everything is back on. just letting it settle. hope there arent any spots on the ground in the morning.
6 straight hours of working on her. the most i have ever spent in one sitting. i gotta lot done thought. haha broke a bolt for the front crossmember in the hole other than that it went well. still have a bit more to do tho -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jan 5, 2009 - 9:50 AM |
Enthusiast Joined Jan 5, '09 From York, Pa. Currently Offline Reputation: 0 (0%) |
HI Guys. I'm brand new to this forum, and this sounds so familiar. I did the dizzy o-ring, fought with the crossmember and did the oil pan gasket, etc., and guess what it was the rear main seal. UGH-. This leak is very hard to diagnose because it travels down the crossmember and other things and it drips from many spots. The giveaway drip is the one thats coming from the little square weephole that is on the bottm of the girdle -like thing that is between the engine and tranny(mine is auto). This is my first time dealing with an engine pull in a front wheel drive car and its a PITA. especially the wiring harness on these cars, they way it is routed thru the intake manifold.
Has anyone done the rear seal before? Any tips? The motor will be out of my car and is getting lots done while its out- water pump, head, front seal, etc. |
Jan 5, 2009 - 10:47 AM |
HI Guys. I'm brand new to this forum, and this sounds so familiar. I did the dizzy o-ring, fought with the crossmember and did the oil pan gasket, etc., and guess what it was the rear main seal. UGH-. This leak is very hard to diagnose because it travels down the crossmember and other things and it drips from many spots. The giveaway drip is the one thats coming from the little square weephole that is on the bottm of the girdle -like thing that is between the engine and tranny(mine is auto). This is my first time dealing with an engine pull in a front wheel drive car and its a PITA. especially the wiring harness on these cars, they way it is routed thru the intake manifold. Has anyone done the rear seal before? Any tips? The motor will be out of my car and is getting lots done while its out- water pump, head, front seal, etc. actually, you should pull the harness out along w/ the engine. 2 bolts where the harness goes into the firewall, and 4 plugs. 3 on the ECU and one on the heater blower. makes it SO much easier. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jan 5, 2009 - 1:23 PM |
HI Guys. I'm brand new to this forum, and this sounds so familiar. I did the dizzy o-ring, fought with the crossmember and did the oil pan gasket, etc., and guess what it was the rear main seal. UGH-. This leak is very hard to diagnose because it travels down the crossmember and other things and it drips from many spots. The giveaway drip is the one thats coming from the little square weephole that is on the bottm of the girdle -like thing that is between the engine and tranny(mine is auto). This is my first time dealing with an engine pull in a front wheel drive car and its a PITA. especially the wiring harness on these cars, they way it is routed thru the intake manifold. Has anyone done the rear seal before? Any tips? The motor will be out of my car and is getting lots done while its out- water pump, head, front seal, etc. actually, you should pull the harness out along w/ the engine. 2 bolts where the harness goes into the firewall, and 4 plugs. 3 on the ECU and one on the heater blower. makes it SO much easier. Yes thats what I did.The motor's on the stand finally- It should be fun figuring how to take the harness off the engine! |
Lo-Fi Version | Time is now: November 30th, 2024 - 7:32 AM |
