> What size injectors??, YAMAHA BEAMS 3S-GE
post Dec 26, 2008 - 8:23 PM
Ronan
Joined Jun 3, '08
From Ireland
What size injectors does the Yamaha BEAMS 3S-GE come with as standard?
What size injectors would be the best upgrade when used in conjunction with a fuel pressure regulator and air/fuel controller?
post Dec 27, 2008 - 7:58 PM
Rusty
Joined Nov 5, '07
From New Zealand
your ones are good enough, unless your doing a turbo, much higher compression you properly wont have to change them
you could if you want to, get them flowed?
post Dec 31, 2008 - 8:38 AM
Edophus
Joined Apr 20, '06
according to the manuals there 345cc, actual flow testing puts them about 315cc.
Lo-Fi Version Time is now: November 26th, 2024 - 3:56 AM
