9 Pages V  < 1 2 3 4 > »
> 7A-FTE made in Germany
post Jan 16, 2009 - 1:48 PM
Hafkai
Joined Dec 9, '05
From Germany
Got new pics, there are still some things to do but the engine should run this weekend.
post Jan 16, 2009 - 2:40 PM
Sebby
Joined Jan 12, '09
From Poland,Europe
Grat job mate,keep up the good work!!
post Jan 16, 2009 - 2:49 PM
Nice work, looks like your project is coming along very clean.
post Jan 17, 2009 - 5:02 PM
Hafkai
Joined Dec 9, '05
From Germany
post Jan 18, 2009 - 2:34 AM
normality78
Joined Oct 27, '05
i like the way how you fabricate the downpipe housing. Looks great...
post Jan 19, 2009 - 6:40 PM
Hafkai
Joined Dec 9, '05
From Germany
Today we finaly got everything done what's needed to let the engine run. After 10 minutes wondering why my E-manage and the starter don't work, my friend simply asked me "immobilizer??"... unbelievable how fast you can forget something like that laugh.gif
The engine runs a bit rich at idle and closed loop didn't worked, maybe a problem with the stock lambda probe. Tomorrow we put the car on the dyno and i try to set up the E-manage so that the car will run not too bad with boost, fine tuning will follow the next weeks.
Short video
and some pics
This post has been edited by Hafkai: Jan 19, 2009 - 7:16 PM
post Jan 20, 2009 - 5:11 PM
Hafkai
Joined Dec 9, '05
From Germany
First run with some engine knock because of too advanced ignition timing making the engine stutter above 5000rpm, i retarded the timing about 2-3° in the next runs.
post Jan 20, 2009 - 9:15 PM
normality78
Joined Oct 27, '05
nice figure...!! cant wait to see full dyno plot.
post Jan 20, 2009 - 9:24 PM
normality78
Joined Oct 27, '05
im watching the video but i also notice some knocking sound behind. Is that the engine knock sound you're refering to? Coz i can hear it even on low rpm and gradually increasing as ur rev up
post Jan 21, 2009 - 4:54 AM
Hafkai
Joined Dec 9, '05
From Germany
The loud knocking sounds are from the dyno. The actual engine knocking isn't audible but you can hear that the engine doesn't rev freely in high rpm. Too bad i don't have a video from the other runs.
post Jan 21, 2009 - 4:58 AM
normality78
Joined Oct 27, '05
alright. that's scared me of the loudness. If were at that level, very soon will...... hehehe
post Jan 31, 2009 - 10:39 AM
Hafkai
Joined Dec 9, '05
From Germany
I finally got the car back and it runs great, the exhaust is relatively quiet but sounds wonderful. The E-manage works great but i have to do some settings till ignition and injection are perfect.. still get some engine knock but not as bad as with the old spark plugs. I just did a short test drive on the Autobahn smile.gif i never was that fast on >110mph and the car still pulls very hard, but my clutch decided to die and started to slip real bad.... i'll order a Exedy Stage 2..
short video of 2. - 3. gear, the clutch gripped but the wheels are spinning in 2. gear Link
post Feb 1, 2009 - 6:37 AM
normality78
Joined Oct 27, '05
keep it coming.....
post Feb 11, 2009 - 3:50 AM
eggman40
Joined Aug 17, '04
From California
man that is a GREAT install, i love how clean you installed everything. Especially with the small space your working with.
I would however try and maybe wrap the manifold and the first 2ft of the charge pipe with some heat wrap. that should help a little in keeping the heat from spreading in the engine bay, and more imporatantly the radiator. Ive never seen an exhaust pipe so close to the radiator, Id be a bit a concerned about the radiator breaking at a track day.
post Feb 27, 2009 - 10:48 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
everything looks great. good job
post Apr 20, 2009 - 4:37 AM
Hafkai
Joined Dec 9, '05
From Germany
I went to the track yesterday and the engine seems to like the boost wink.gif, no bigger problems at all, the oil temp was always below 120°C (~250°F) and exhaust gas temp peaked at 930°C (1700°F) @ 6200rpm. The water got a little bit hotter than usual but not too much.
The stock clutch is still in an holds the boost without problems... i'm a little bit astonished about this.
I got a video of the fastest lap.. cam position sucks but i love the engine sound wink.gif Link
I was able to drop the lap times from 2:30 to 2:21 and this with bad tires...
post Apr 20, 2009 - 5:43 AM
QUOTE (Hafkai @ Apr 20, 2009 - 4:37 AM) *
1700*F is VERY hot.
be carefull with temps that high, your dangerously close to melting somthing. wink.gif
post Apr 20, 2009 - 6:31 AM
Hafkai
Joined Dec 9, '05
From Germany
Most of the time the egt is between 1300-1600°F but it can rise to 1650-1700 on the long straight..
It usualy peaks at 1630°F ... 1690°F was the highest i've seen so far.
post Nov 9, 2009 - 9:25 AM
Hafkai
Joined Dec 9, '05
From Germany
After about 7k miles the engine still runs great, i did a compression test some weeks ago with ~190psi on all cylinders. The 7A really can take some abuse.. over 200 miles or 15 turns at the circuit without any problems, even at over 90°F ambient temperature.
The engine gets 10psi boost at all day driving and 7-9psi at the track, depending on the weather thanks to boost creep at low temps....
Oil consumption is a little bit high with almost 1L/1000km... but it could be worse wink.gif
The fuel consumption is not bad with ~27 mpg overall and 20 mpg at the circuit.
I got a short video from the Autobahn, testing 100-200 km/h acceleration at 10psi Youtube
post Nov 9, 2009 - 10:35 AM
What have you done to the internals? Very sorry, I don't remember from the first time reading.
Lo-Fi Version Time is now: November 22nd, 2024 - 12:06 PM
