> Ash tray light, Eeehh
post Dec 28, 2008 - 9:29 AM
Seztor
Joined Mar 23, '08
From Denmark
Hi
To you guys that got the 74 out of the ash tray, WTF did you use :X??
[font=CELICA FOREVER][/font]
post Dec 28, 2008 - 9:41 AM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
i pulled the bezel off the shifter, moved my shift boot aside and reached back there. only other way i can think of is to pull the center console up.
~Andy
Check out my Droid Goodies
| My Flickr
post Dec 28, 2008 - 10:23 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
yeah if you take the shifter trim out reach under the console and it should twist out.
post Dec 28, 2008 - 10:40 AM
stetsonaw
Joined Aug 3, '07
~Andy
| My Flickr
post Dec 28, 2008 - 11:47 AM
brk34
Joined Jan 20, '08
pulling out the center console isn't that hard just make sure not to loose any bolts or screws
post Dec 28, 2008 - 12:32 PM
Seztor
Joined Mar 23, '08
From Denmark
post Dec 28, 2008 - 12:54 PM
vincent_doggy
Joined May 25, '06
From Hong Kong
QUOTE (Seztor @ Dec 29, 2008 - 1:32 AM) *
Do u swap with a white led one instead... much brighter than stock... I serve the Ashtray as coin cointainer since I am a non-smoker, that little bulb help a bit to search coins ...
This post has been edited by vincent_doggy: Dec 28, 2008 - 12:54 PM
post Dec 28, 2008 - 1:03 PM
Seztor
Joined Mar 23, '08
From Denmark
QUOTE (vincent_doggy @ Dec 28, 2008 - 1:54 PM) *
I put an blue led instead. But i think i will change it later with a white instead.
I also use it to coins hehe =)
post Dec 28, 2008 - 1:36 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
I didn't even know there was a light in there, guess mine's busted...I'll look for it.
post Dec 28, 2008 - 2:15 PM
Seztor
Joined Mar 23, '08
From Denmark
post Dec 28, 2008 - 4:29 PM
CelicaST_CALI
Joined Feb 28, '07
BANNED. for life, you moron.
post Dec 28, 2008 - 5:55 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
There's not one in mine either...
post Dec 28, 2008 - 9:56 PM
there is, the bulb is just out.
post Dec 28, 2008 - 10:43 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
But is it in the tray itself or under? There's no wires going into the tray nor is there a light under it...or are you talking about the one in the rear?
post Dec 28, 2008 - 11:33 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
if you remove the tray rjb, and look closely you will see that there is a clear window on the rear facing side of it. Then, look through the hole where the ash tray sits and look for where the clear window would line up with in there, you'll see it, probably has the nasty green thing on it still. biggrin.gif The best way to change it really though is by taking out the whoel console so you don't break any of the aging plastic clips.
My F/S Thread!
Ferdi says (11:29)
post Dec 28, 2008 - 11:43 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
i used q-tips to massage the bulb out. replaced it with it a green one. biggrin.gif
post Dec 28, 2008 - 11:52 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (samir0189 @ Dec 29, 2008 - 12:33 AM) *
x2. I just had my console out a few days ago, installing a new light in the storage compartment. It makes life a whole lot easier to take 5 minutes to undo 2 screws and 2 bolts and take the console out then try to work with it where you can't see it.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 29, 2008 - 10:23 AM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Aight, thanks guys.
post Dec 29, 2008 - 3:00 PM
Seztor
Joined Mar 23, '08
From Denmark
Rick:
Did you find your bulb biggrin.gif?
Or do you want me to take a picture mate smile.gif?
post Dec 29, 2008 - 3:52 PM
RickJamesBish
Joined Jun 21, '08
From Naples, FL
Haven't checked yet, I'm sure I'll be able to find it.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:45 AM
