> need your help, idle problems
post Dec 28, 2008 - 3:51 PM
6gcnoob
Joined Mar 10, '08
From Ct
ok so heres the low down
i orignialy started out with a high idle of around 1500-2k rpm
searched the forums and read that my IAC valve most likely the problem and to take it off and clean it.
took it off and cleaned it put it all back together, start the car and the rpms are jumping from 1 to 2k, figuring it could be the Throttle Position Sensor i loosend it and moving it to a smooth idle, but the smooth idle is at 3k. what could be the problem? great help is appriciated.
post Dec 29, 2008 - 11:42 AM
6gcnoob
Joined Mar 10, '08
From Ct
com'on guys i really need some advice, i dont know what to do
post Dec 29, 2008 - 4:10 PM
Remy
Joined Jan 25, '06
From MN
Sounds like you might have a vac leak double check and make sure you have no cracked or lose hoses. Adjust your tps sensor to oem spec. Does your car throw any codes ?? How many miles on your motor ?? Did it just start idling high out of no where or did you always had this problem ??
"To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version Time is now: February 21st, 2025 - 11:53 PM
