> parking brake pads/ help, rear drum will not fit over new parking barking pads
post Dec 30, 2008 - 11:06 PM
celica95-95
Joined Aug 4, '06
From Toronto
Just put on new parking brake , try to put rear drum ill will not fit on,
This post has been edited by celica95-95: Dec 30, 2008 - 11:09 PM
post Dec 30, 2008 - 11:37 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
there is an adjustment wheel at the bottom of the drum assembly, you gotta adjust it in so that the pads come closer together, then fit the rotor on, then line up the hole in the rotor with the adjustment wheel at the bottom and adjust it back out.
My F/S Thread!
Ferdi says (11:29)
post Dec 30, 2008 - 11:47 PM
celica95-95
Joined Aug 4, '06
From Toronto
QUOTE (samir0189 @ Dec 31, 2008 - 12:37 AM) *
I have the adjustment set all the way , and still will not fit, all spring are tight as well,
post Jan 1, 2009 - 10:33 AM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
did you get aftermarket shoes or toyota?
Trust me, I do this every day
post Jan 2, 2009 - 2:35 PM
celica95-95
Joined Aug 4, '06
From Toronto
QUOTE (silver6gc @ Jan 1, 2009 - 10:33 AM) *
post Jan 2, 2009 - 8:47 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
This might sound totally retarded, but is your parking brake engaged? Only reason why I ask is I was doing my rotors a while ago and did the front no problem, then went to the rear and couldnt get them off. Turns out I had a helluva time trying to manhandle it, when i realized my parking brake was still set. If your brake is set the rotor will not go over it. Sometimes its the stupid things....
post Jan 3, 2009 - 12:47 AM
celica95-95
Joined Aug 4, '06
From Toronto
QUOTE (Spider77 @ Jan 2, 2009 - 9:47 PM) *
na i wish that was it , going back in morning to work on it left for a cpl days
Lo-Fi Version Time is now: February 22nd, 2025 - 5:32 AM
