Short handle E-Brake |
Jan 2, 2009 - 12:52 PM |
Enthusiast Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) |
if you take your consol out you can see that the handle is nothin more then (bolted) it's more of a rivit deal with 2 ends...its hard to explain...but if you can pop off the "rivits" then you can get another e-brake and make your own holes and just put the little bolts right back through...its not just a handle...it actually has a flat metal piece that gets rivited to the actual assembly..i think you can get any e-brake to work its just that a toyota or lexus would be easier to modify.
-------------------- I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
Jan 17, 2009 - 5:04 PM |
Enthusiast Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
if you take your consol out you can see that the handle is nothin more then (bolted) it's more of a rivit deal with 2 ends...its hard to explain...but if you can pop off the "rivits" then you can get another e-brake and make your own holes and just put the little bolts right back through...its not just a handle...it actually has a flat metal piece that gets rivited to the actual assembly..i think you can get any e-brake to work its just that a toyota or lexus would be easier to modify. I don't think it is that simple with the MR2 handbrake. Overall, I think you are right - there are probably other toyota or lexus brakes that we can just swap in or modify by poping the rivets and swapping out bits. But the MR2 handbrake isn't one of them and here is why: On the left we have the MR2 handbrake, on the right, a Celica handbrake (which happens to have a modified handle - but more about that later). You can clearly see that the rivet positions and the operation of the handbrake switch is quite different. But here is the killer:Radius of the ratchet on the Celica handbrake: 75mm. Radius of the ratchet on the MR2 handbrake: 68mm. Now, about that modified handle: http://www.6gc.net/forums/index.php?showtopic=64906 This post has been edited by BloodyStupidDavey: Jan 17, 2009 - 5:05 PM -------------------- Davey
Items for sale |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:04 PM |
