2 Pages V  < 1 2
> ST205 WRC Swap ST165, Old news, but new to 6G
post Jan 2, 2009 - 5:22 PM
MR2Guru
Joined Dec 12, '08
From North Carolina
QUOTE (Batman722 @ Jan 2, 2009 - 12:52 PM) *
nice swap ! that's a great upgrade from the 165 !
I'm definitely in love. Its been so fun, its hard to convince myself to further modify it! I would have loved to have the ST205 rear diff, but maybe I will acquire that in the future. I do now have the option to bolt on the GReddy 20g, but I cant yet afford engine management so that is on hold for the time being. I cant imagine how fun it could be then!
Visit My Myspace
Visit My Work
413whp Stock Cam 1991 MR2 Turbo
1988 Supercharged MR2 w/NST Clutchless SC Pulley (Designed by yours truly)
1988 Celica All Trac with ST205 WRC swap
post Jan 2, 2009 - 5:25 PM
MR2Guru
Joined Dec 12, '08
From North Carolina
Quick question, to those other WRC engines/cars..... Where is your fuel cut? Speed Cut? My car wont fuel cut til 20psi *shrug* I hear this should be 17-18psi. Tested 2 different boost gauges, same results. Could be due to my elevation maybe. I havent hit speed cut yet. I have had her up to 148mph (looked like 150), but never hit speed cut. Not sure if there even is one. I have yet to determine if my WRC engine is UK or JP spec.
Thanks!
Visit My Myspace
Visit My Work
post Jan 2, 2009 - 9:35 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
You can put the 20G on now without any engine management necessary. There is plenty of power to be had going from the stock 20b to the 20g, and your stock 550s will handle the new turbo without any problems. Put it on, send it to the dyno, and turn up the boost!
As far as boost cut, mine seems to be around 20psi as well....I stated it in my swap thread, but I thought it just had to do with the map sensor not reading/sending signal to the ecu as fast as my Autometer boost gauge could read 20psi......Maybe its a WRC thing. I installed a FCD on my setup and still have to adjust it to eliminate boost cut COMPLETELY.
330whp 309ft/lbs @ 21 PSI
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 23rd, 2024 - 12:06 PM
