> Start-up, blowers at startup
post Jan 2, 2009 - 1:57 PM
cibrit-
Joined Sep 16, '08
From Michigan
I wasn't sure where to post this, but since this section is about the 3SGTE swap, I figured it would be fine to put it here. So, I wanted to know if at start-up, before turning the key to actually start the car, that the blowers should kick on.
Whenever I turn the key to the fullest just before it needs to be turned to start the car, my blowers kick on... Is this a problem that I should fix or is it something that I shouldn't be worried about?
Please help with this and if you guys need a video of the start-up just let me know so you can see what exactly I am talking about.
*Thanks
94' Red Celica ST Hatchback: 3S-GTE Swap
Upgrade??: ATS CT27 Kits
-Toni
post Jan 2, 2009 - 3:00 PM
You mean the radiator fans? Its normal for a 3sgte swap in an st, because your st radiator doesn't have the temp sensor needed to know when to cycle the fans on/off, so your fans always stay on. Not a big deal.
If you ever have to replace the radiator, get a GT one and find a temp sensor for it from a junk yard. That would fix the problem.
post Jan 2, 2009 - 9:42 PM
cibrit-
Joined Sep 16, '08
From Michigan
-Toni
post Jan 2, 2009 - 10:59 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
same thing happened when i put the engine back in my all-trac. it was from a sensor unplugged on the AC lines
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
Lo-Fi Version Time is now: December 3rd, 2024 - 10:11 AM
