2 Pages V  < 1 2
> Battery Light on?!, Please help
post Jan 6, 2009 - 10:28 AM
DEATH
Joined Dec 19, '07
From tx
Random - you have a wire fixing to come loose. Should find it and fix it now.
OP - If you have done all you say I agree with Stephen - the wire going to your gauge cluster must have burnt somewhere. Locate it and do a continuity test on it
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 6, 2009 - 11:19 AM
99GT
Joined Dec 14, '06
From MN, USA
I'm gonna try an alternator from muggs first then there apart the wiring harness again. kindasad.gif
post Jan 6, 2009 - 8:30 PM
99GT
Joined Dec 14, '06
From MN, USA
I went and got everything retested.
With the new batt, my sis bought me.
14.25 at idle.
The oreilly guy said that when we redid the harness, we should of used the same gauge wire. I used some bigger gauge wire when we did it.
Do you guys think that might be my problem?
But anyways my new used complete harness came in.
post Jan 9, 2009 - 11:22 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
QUOTE (DEATH @ Jan 6, 2009 - 7:28 AM) *
Really? I thought it was just that plug in part. Ok, I will check it out this weekend. I haven't driven my poor car in a week. Waiting on some funds for spark plugs and such. Plus trying to get to that rear mount hopefully this weekend.
post Jan 15, 2009 - 12:36 PM
spotv6
Joined Jan 6, '09
From stoke on trent england
dont know wether this would help
but i had battery light come on
on investigation the wiring that goes to the plug on the alternator had snapped which results in the battery light on the dash coming on
could be worth examining the plug?
post Jan 15, 2009 - 3:33 PM
99GT
Joined Dec 14, '06
From MN, USA
I will look into this. Thanks.
post Jan 15, 2009 - 5:28 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
Any lights on other than the battery light? Does it go off and on at times? I'm having the same problem - battery light is on and eventually after driving a little while, the airbag light comes on too. Drove hard over a pothole this morning and the battery light went out and didn't come back on the whole way to work.
I've narrowed it down to a bad ground or bad alternator. I also very recently replaced my alternator, and then the battery (which it turns out I didn't need to replace, so now I've got 2. kindasad.gif )
Check all your grounds. One of mine completely melted (which was why I couldn't start my car, and erroniously bought a new battery). I replaced that ground and then it was good for a few days, and then the light came back on. So I replaced other grounds, added a few, and still - evil red rectangle. I keep being told too that it's a regulator issue, which means the alternator is bad. I was also told that testing the alt won't always tell you there's a problem; it might just tell you there's a generic "charging system" problem which is really vague.
post Jan 16, 2009 - 8:09 AM
99GT
Joined Dec 14, '06
From MN, USA
All accesories running at idle I was still at 14.25.
All grounds check and cleaned, No other light, Alt tested also, new batt, alt fuse checked.
althought last week attempted to take out my harness for a new one, my cell is on now.
post Jan 28, 2009 - 12:56 PM
GriffGirl
Joined Feb 7, '07
Did you ever get this resolved?
I'm 10 or 12 days on a replacement for my replacement alt and still no electrical issues on the new one. yet. Fingers crossed...
2 Pages V  < 1 2
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 12th, 2024 - 9:44 AM
