Fog Light Question, Running the fog lights to turn on with the parking lights |
Jan 5, 2009 - 3:29 PM |
Enthusiast Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Hey guys,
I have the 96-99 fog lights already installed in my car. I was just wondering how can I run them to turn on when you just have the parking lights on? Right now, it only turns on when I put the headlights on. Oh, and I have the OEM light switch for the fog lights and I'm not thinking of running another aftermarket switch just for this. |
Jan 5, 2009 - 5:00 PM |
I know of a how-to to do this, if you want me to get it for you. The catch is, the fog lights would be on when the parking lights are on, no matter what. I'm sure you could install a new switch yourself and get around that, but it's a fairly simple mod if you want me to find the link. I've been planning on doing it to my car so my fogs are on all the time, even with my brights.
Jan 7, 2009 - 2:12 PM |
Sorry this took so long. It slipped my mind. Here is the link to that fog light modification article. This was written for a 5th gen but will apply to our cars also.
http://www.toyotacelicaonline.com/fogs.htm -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Feb 9, 2009 - 12:58 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
do the 94-95 celicas have that relay already?
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Feb 9, 2009 - 7:25 PM |
wire it directly if you want to be able to turn on the fogs by itself seperate from the low beams.
Feb 11, 2009 - 3:22 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
wire it directly if you want to be able to turn on the fogs by itself seperate from the low beams. Just wire the power to the fogs directly from a key-on 12v source instead of from the headlights. Right now they get the power to the relay from the headlight switch. -------------------- 1999 Celica GT
Feb 11, 2009 - 4:03 PM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Let me look at the wiring for the car. There might be a way to simply move the trigger for the fog lights from the headlight circuitry to the parking lamp circuitry. I'm going to be in there this weekend so I'll try to remember to take a look.
Feb 11, 2009 - 5:09 PM |
Hey guys, I have the 96-99 fog lights already installed in my car. I was just wondering how can I run them to turn on when you just have the parking lights on? Right now, it only turns on when I put the headlights on. Oh, and I have the OEM light switch for the fog lights and I'm not thinking of running another aftermarket switch just for this. You might be able to Tee in a wire from the side markers to the fogs. That way when the side markers turn on, they will power the fogs. This post has been edited by lagos: Feb 11, 2009 - 5:11 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 12, 2009 - 12:20 AM |
I would not rob the headlight wiring of anything, my friend caused more than 500 dollars of damage when he did that, just run it directly to the battery using an OEM switch I prefer, and thats what I did.
Feb 12, 2009 - 4:08 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
It is possible to turn fogs on anytime you want
- with ignition on - with parking lights on - with low beams on - with high beams on - even with turn signals only you need is: a) remove foglight relay b) plug pair of wires instead of that c) other end connect to "switching mechanism" (for you it means find where switch contacts for parking lights are... so just find two correct wires on multi-switch for headlights and connect it there) no cutting, no irreversible processes at all... -------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Feb 13, 2009 - 11:53 AM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
c) other end connect to "switching mechanism" (for you it means find where switch contacts for parking lights are... so just find two correct wires on multi-switch for headlights and connect it there) b) plug pair of wires instead of that Are these the (+)'s from both the fogs? This post has been edited by KAOS: Feb 13, 2009 - 11:55 AM -------------------- |
Feb 13, 2009 - 1:54 PM |
Malpaso, I'm gonna do that to my car when I get a chance! But because I'm a wiring noob... I have to ask the dumb question of the day. What did you use to plug the wires into where the relay was?
Feb 13, 2009 - 1:58 PM |
Malpaso, I'm gonna do that to my car when I get a chance! But because I'm a wiring noob... I have to ask the dumb question of the day. What did you use to plug the wires into where the relay was? You should be able to get away with using this: -------------------- |
Feb 14, 2009 - 2:40 AM |
c) other end connect to "switching mechanism" (for you it means find where switch contacts for parking lights are... so just find two correct wires on multi-switch for headlights and connect it there) b) plug pair of wires instead of that Are these the (+)'s from both the fogs? relay it self has four wires. two are "switching" ones (when signal comes they just do the job of the switch) and other two are just "connecting" (those you connect together... connected = fogs are on, not connected = fogs are off). I'm using those "connecting" ones. If you make shortcut between those two wires in the picture your foglights will be permanently on. Malpaso, I'm gonna do that to my car when I get a chance! But because I'm a wiring noob... I have to ask the dumb question of the day. What did you use to plug the wires into where the relay was? You should be able to get away with using this: exactly that's what I have used... -------------------- No more replicas... This is evolution... This is SS-four :)
Feb 17, 2009 - 9:42 AM |
relay it self has four wires. two are "switching" ones (when signal comes they just do the job of the switch) and other two are just "connecting" (those you connect together... connected = fogs are on, not connected = fogs are off). I'm using those "connecting" ones. If you make shortcut between those two wires in the picture your foglights will be permanently on. So if I don't have the foglight switch in the cab of the car; but I have the relay (which I'm not sure if I do or don't, I haven't looked lately) would wiring them like this work for me? You wouldn't happen to have a wiring diagram of what you've got done in this picture, would you Malpaso? -------------------- |
Feb 17, 2009 - 11:23 AM |
So if I don't have the foglight switch in the cab of the car; but I have the relay (which I'm not sure if I do or don't, I haven't looked lately) would wiring them like this work for me? yes. I have done that already once as well . If you have relay only you need is provide "switching signal" to have relay on-state to switch on lamps. You wouldn't happen to have a wiring diagram of what you've got done in this picture, would you Malpaso? sorry I don't... but I can try to draw something -------------------- No more replicas... This is evolution... This is SS-four :)
Feb 17, 2009 - 11:26 AM |
So if I don't have the foglight switch in the cab of the car; but I have the relay (which I'm not sure if I do or don't, I haven't looked lately) would wiring them like this work for me? yes. I have done that already once as well . If you have relay only you need is provide "switching signal" to have relay on-state to switch on lamps. You wouldn't happen to have a wiring diagram of what you've got done in this picture, would you Malpaso? sorry I don't... but I can try to draw something As always: -------------------- |
Feb 18, 2009 - 5:38 AM |
You wouldn't happen to have a wiring diagram of what you've got done in this picture, would you Malpaso? So... I have found one already created by Dustin: and just to match my terms wires of relay I have talked about: "switching" ones: #85, #86 "connecting" ones: #30, #87 Wires in the picture below are using pins #87 and #30 (according to picture above). That's why when you make shortcut between those two wires foglights will be permanently on... ...and just to make info complete here is description of OEM relay (lower one in the picture of course ) taken from Toyota's repair manual. You can find out which pin is what -------------------- No more replicas... This is evolution... This is SS-four :)
Feb 18, 2009 - 6:20 AM |
is that from the celicatech manual or a toyota shop manual?
Feb 18, 2009 - 7:00 AM |
Enthusiast Joined Dec 21, '06 From New Zealand Currently Offline Reputation: 0 (0%) |
As an aside, is this required only on USDM celicas? As my JDM one has said capability on the stock stitch from factory.
Lo-Fi Version | Time is now: November 26th, 2024 - 12:38 PM |
