Will this spray gun will be compatible with my compressor? |
Jan 6, 2009 - 3:25 AM |
Enthusiast Joined Nov 18, '08 From WI Currently Offline Reputation: 0 (0%) |
I'm planning on painting my celica and i was just wondering if this devilbliss HVLP spray gun will be compatible with my 33gal. craftsman air compressor.
here are the specs: Spray gun: 30 PSI inlet pressure delivers 10 PSI air cap pressure at 13 CFM air volume. Air Compressor: 1.6hp, 33 gal., 150max psi, SCFM Delivery At 40 psi: 6.3 SCFM, SCFM Delivery At 90 psi: 4.9 SCFM I was just wondering if the gun will be able to spray a good amount of paint on the car with a good finishing touch. Will the tank be able to supply enough air for the paint job with no wait for charging? |
Jan 6, 2009 - 7:22 AM |
i dont think so. you barely have 6.3 at 40 psi.
Jan 6, 2009 - 3:15 PM |
agreed. you're pulling double what your a/c can provide
Jan 6, 2009 - 3:24 PM |
dang...wasted money on that piece of crap compressor then...anybody know of a nice spray gun that produce low scfm or have used one?
Jan 7, 2009 - 5:27 AM |
somthing non hvlp would be a better choice.
13.6@108MPH, 5SFTE Powered |
Jan 7, 2009 - 7:37 AM |
Enthusiast Joined Dec 14, '06 From MN, USA Currently Offline Reputation: 2 (100%) |
Just return it.
Jan 7, 2009 - 3:44 PM |
i can't return it, because i purchased this air compressor a year ago. i'll just go with a non hvlp gun or go with this NEIKO HVLP gun I found that produce low scfm.
operation pressure is 40psi : 4.5 cfm comes with 1.5, 1.7, 2.0 tip |
Jan 7, 2009 - 4:01 PM |
It should work with that spray gun. I don't see why a 33gal can't do the job. Just don't use it for a long period of time.
Jan 8, 2009 - 1:50 AM |
Enthusiast Joined Apr 23, '06 From Rochester, NY Currently Offline Reputation: 8 (100%) |
Sharpe makes a spray gun that is LVLP (low volume, low pressure). i believe you could get your compressor to work with it. it requires quite low cfm. ill let you know about pricing, model, and actual specs of the gun tomorrow after work.
Erich |
Jan 8, 2009 - 6:04 PM |
go to home depot and buy their gun. Thats the one i have. Its 50 bucks. it requires 7 scf but it may help. their brand is husky.
Jan 9, 2009 - 6:00 AM |
njccmd2002, how does that husky spray gun from home depot work for you? did it give you a smooth finishing touch?
Badkarma, did you find the specs on the spray gun that sharpe makes? j/w |
Lo-Fi Version | Time is now: November 24th, 2024 - 7:18 PM |
