> engine failer
post Jan 6, 2009 - 5:19 PM
stryue_19
Joined Apr 12, '08
From St.Paul
i was drivng for 30 mins parked my car came back out in bout 10mins started my car when pull down the drive way an it died so i craked it up 2 to 3 times an it still wouldn't start finally i got it to start went about half a milde an stopped at the lights. an it died on me again an i tried to start it but this time it wouldn't start at all....so i had it towed home an i took one of mine spark plug out an cranked it but there was no spark...
so i'm wondering what it wrong with it?
post Jan 6, 2009 - 5:29 PM
cloqwise
Joined Dec 10, '08
From Peterborough/Salisbury/Middlesbrough UK
QUOTE (stryue_19 @ Jan 6, 2009 - 5:19 PM) *
This may sound daft but are both your leads attached securely to the battery? That kind of happened to mine when the earth lead wasn't tightened properly
You Take Them Spoons Away He Cry Like A Baby, Mother F*ucking Spoon Love
post Jan 6, 2009 - 5:36 PM
trd94
Joined Jan 9, '05
From green springs ohio
also could be a crankshaft, or a camshaft position sensor . with out a signal from them it tell the ecu it is not in tdc and to shut off the spark.
post Jan 6, 2009 - 5:38 PM
bmj67
Joined Oct 23, '08
It could be a few things check all of your plug wires are secure. Check the distributor cap and rotor they may need replaced.
post Jan 7, 2009 - 12:22 AM
Salica
Joined Dec 28, '08
From long beach, CA
Hey,
I would say start with the easy first... check your spark plug cables, check your spark plugs, check for signs that there is fuel in the chambers. those are some basics there are more but i cant think of it atm.
post Jan 12, 2009 - 5:27 PM
stryue_19
Joined Apr 12, '08
From St.Paul
well thanks guys for the tips..i'll see what happens..
Lo-Fi Version Time is now: December 2nd, 2024 - 10:32 AM
