> looking for the right amp., what size amp should i get to power 2 10" 400 watt rms subs
post Jan 7, 2009 - 7:11 PM
Zeros2
Joined Sep 25, '08
From colorado
Hi guys i was just wondering what size am i should buy if i wanted to get the most out of my 2 10" 400 watt rms 800 watt peak sub. I believe they are 4 ohm subs if that has anything to do with it. and the brand is Visonik. Thanks for the help
post Jan 7, 2009 - 9:05 PM
richee3
Joined Jun 29, '08
From Denver
Find an amp that matches your subs. You say your subs are 400 watt RMS, 800 watt max. Find an amp that matches that.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 8, 2009 - 5:06 PM
trdproven
Joined Aug 2, '05
From Guam
really there is a performance chart, if you go under the matching wattage, you don't maximize potential. If you go over, there is a chance of damaging something. Again, that is a combo of things like bridging techniques.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 8, 2009 - 6:10 PM
Ugglan
Joined Jan 8, '08
From Sweden
so, is it better to have a too small amp or should the amp be bigger then the sub(s)? (and then you just have to be carefull with the volume?)
Smaller amp mening less power (watts)...
And sure, the exact same power must be the optimal but i don't have that option... smile.gif
post Jan 8, 2009 - 8:14 PM
Zeros2
Joined Sep 25, '08
From colorado
ok well i was thinking about a 1000 watt amp and wiring the subs in parallel to split it 500x @ 2ohms so that would keep both sub around 100-150+ watts or so over the 400 rms rating correct me if im wrong, but is this a good idea?
post Jan 8, 2009 - 9:24 PM
richee3
Joined Jun 29, '08
From Denver
No. Bad idea. I thought the same thing once. I was buying a new sub the next day, just from keeping my amp 150 watts over RMS for the sub. When the sub is rated for a certain wattage continuously, that's what it means. Not continuously 150 watts over that.
Also, if your subs are 4 ohm like you said in the first post and you push them at 2 ohm, you're buying new subs for sure. kindasad.gif
This post has been edited by richee3: Jan 8, 2009 - 9:26 PM
1998 Celica GT-
BEAMS Swapped.
post Jan 9, 2009 - 2:56 AM
trdproven
Joined Aug 2, '05
From Guam
Its better to be slightly less under than way over.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 23rd, 2024 - 10:54 PM
