> Ariel not fully retracting grrr
post Jan 11, 2009 - 9:12 AM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
Hi all just wondered if anyone had a similar problem. The ariel won't fully retract it stays out about 8" and I'm worried some braindead's going to snap it off
Many thanks in advance
post Jan 11, 2009 - 12:24 PM
Culpable04
Joined Apr 17, '06
From New Jersey
does it keep trying to retract ? you can buy a rebuild kit for it or just grab a used one from ebay. you can also convert to a s2000 aerial which is smaller and sportier.
post Jan 11, 2009 - 1:22 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
QUOTE (Culpable04 @ Jan 11, 2009 - 12:24 PM) *
It doesnt keep trying, no its like the end point had decided to be a few inches sooner than it should be. cant force it down by hand either, it keeps springing back like a shock absorber! do i have to replace the whole unit then, theres no way i can just reset the relay or something?
post Jan 11, 2009 - 1:28 PM
Culpable04
Joined Apr 17, '06
From New Jersey
there I can't help you, my aerial came defective with the car, so I never got to play around with it, I'm just replacing it. but I'm sure others will know exactly what to do.
post Jan 11, 2009 - 2:38 PM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
ok, thanks for trying though, its much appreciated
post Jan 11, 2009 - 11:22 PM
dgbldr
Joined Sep 19, '08
From Michigan
No, there is nothing to reset. Your problem is mechanical.
First, if you're mechanically capable, take the whole antenna (aerial) assembly out of the car and take it apart. There may be something jamming the mast.
If it's not jammed, you will find the toothed drive cable broken or stripped. If so, you will need to buy a replacement mast kit, about $70 from a dealer in the US. It will contain a new telescoping mast with new drive cable.
Replacing the whole unit is much, much more expensive and unnecessary if the motor works.
If you're not mechanically inclined, a competent shop can do the replacement mast in an hour's worth of labor.
post Jan 11, 2009 - 11:26 PM
Jaws4God
Joined Mar 27, '04
QUOTE (dgbldr @ Jan 12, 2009 - 4:22 AM) *
x2.. its what happened to mine... they aren't very expensive on Ebay.
post Jan 12, 2009 - 7:17 AM
hardcoreproducer
Joined Jul 2, '08
From Midlands, UK
post Jan 12, 2009 - 10:22 AM
my mast was 34 dollars from 1sttoyotaparts.com. check it out.
post Jan 12, 2009 - 11:22 AM
DEATH
Joined Dec 19, '07
From tx
The stock antennaes are the only lemon on our cars I've always said. Toyota retractable antennaes are the absolute sux. Better to spend your money on a nicer replacement or you'll be doing this again in a year or two
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 12, 2009 - 12:53 PM
zero07
Joined Apr 15, '07
From san antonio tx.
Just shave it off like i did! That things soooo fugly.
post Jan 13, 2009 - 3:07 AM
dgbldr
Joined Sep 19, '08
From Michigan
QUOTE (DEATH @ Jan 12, 2009 - 11:22 AM) *
I have had several used cars, all different brands, with same issue. I have replaced the masts and none ever broke again. Secret: they don't get cleaned. They are retracted when going through car wash or hand washing and people don't think to put them up and clean them. Dirt is what kills them.
Lo-Fi Version Time is now: November 23rd, 2024 - 3:29 AM
