> Why MR2 Power FC do not fit exactly in the ST205??
post Jan 11, 2009 - 11:30 AM
miguelst205
Joined Apr 14, '08
From Paraguay
Hi guys..
Looking in the web for the ST205 3SGTE Gen 3 Power FC Plug n' Play i found this product on Berk Technology, for the MR2 3SGTE Gen 3.. http://www.berktechnology.com/shop/product...35&P_ID=480
so.. there says: "Re-wiring required for use on the 94-up Celica ST205 Alltrac".. my question is WHY???.. it's supposed they are same OEM Ecu, engine, etc, right???..
In case it's necessary a re-wiring, what should be changed and how???...
Thanks in advance.. Best regards..
Miguel..
No se sabe de lo que se es capaz hasta que se intenta... ;)
post Jan 11, 2009 - 9:02 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Im running an MR2 Power FC Pro ecu in my 205, no mods needed, straight plug in.
In some cases the ecu/wireing loom is a little bit different in some cars depending on destination. EG. to run a jdm ecu in an adm car you need to swap a couple of pins over, because their output point on the ecu is in a different spot. Not hard if you have the correct wireing diagrams.
As for the gen3 mr2/st205 there was no australian delivered turbo sw20 mr2's, but obviously there was 205's and like i said im using the mr2 pfc pro in mine with no mods. I say go for it.
This post has been edited by Cuts_the_Pilot: Jan 11, 2009 - 9:05 PM
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Jan 11, 2009 - 11:02 PM
miguelst205
Joined Apr 14, '08
From Paraguay
Ok cuts.. thanks.. but my ST205 is a JDM.. it's the same too??..
Do you have the exactly part number of the POWER FC PRO Version???.. That version have the two step launch control, right???.. It's very hard to find it... right??..
This post has been edited by miguelst205: Jan 13, 2009 - 3:59 PM
post Jan 13, 2009 - 3:59 PM
miguelst205
Joined Apr 14, '08
From Paraguay
post Jan 13, 2009 - 7:01 PM
jackett
Joined Dec 11, '06
From Ireland
I would say the "re-wiring" would have to do with the chargecooler (if you still have one)
If you fit a Gen3 MR2 Power FC in to your ST205 it won't control your chargecooler. So you would have to fit a front mount intercooler or "bridge" the chargecooler to run constantly. The Power FC will fit without rewiring.
post Jan 16, 2009 - 5:33 PM
miguelst205
Joined Apr 14, '08
From Paraguay
Ok jackett.. thanks for the answer.. but, one more question.. hehe..
If I fit a FMIC nothing more is necessary to do, right???.. only plug it and ok???..
People, do you know some place where I can find the Power FC Pro???.. or then where I can find this Power FC MR2 3SGTE Gen 3 with the Hand commander in a good price???.. I only can buy in a shop, store, ebay or something like these sites... new of preference!!..
post Jan 18, 2009 - 1:52 AM
Cuts_the_Pilot
Joined Dec 15, '02
hey man, sorry i dont visit this site often.
i got my power fc direct from apexi just before they stopped making them. Yes its the one with launch control and hard and soft limiters (cuts ignition and fuel insted of just fuel like the normal power fc's), they would be hard to find yeah. The part number is 414-T001.
the pfc pro wont run the intercooler pump so there is no need to bridge any sensors or try to fool the ecu that the pump is still there or whatever, so fmic is the only way to go, better anyway, neater, lighter, make more power, little to no loss in drivability or responce...regardless of what anyone says.
Looking on ebay might be your best bet, or yahoo japan.
here is an example how the ecu pinouts can differ, sure its for gen 2, but it shows how it changes with years etc.
post Jan 18, 2009 - 7:06 AM
you can get both the PFC and hand commander for ~800 from mr2oc.com
you have to register to view, (trust me, its worth it) but here is the link.
http://www.mr2oc.com/showthread.php?t=316571
post Jan 19, 2009 - 6:54 PM
jackett
Joined Dec 11, '06
From Ireland
QUOTE (Cuts_the_Pilot @ Jan 18, 2009 - 6:52 AM) *
If you do not have a FMIC and you have a MR-2 genIII Power FC pro or otherwise fitted there is a big need to bridge the chargecooler pump to run constant.
This post has been edited by jackett: Jan 19, 2009 - 6:59 PM
post Jan 19, 2009 - 6:58 PM
jackett
Joined Dec 11, '06
From Ireland
QUOTE (miguelst205 @ Jan 16, 2009 - 10:33 PM) *
Yep, if you have a FMIC fitted then you can plug in your MR-2 3SGTE genIII Power FC and away you go. You should register on www.gt4oc.net Lots of info primarily on the ST205.
post Jan 20, 2009 - 6:35 AM
3TST
Joined Sep 27, '02
From UK
You should register on www.gt4oc.net. Lots of info. primarily on the ST205
On GT4OC someone currently selling an Apexi Power FC and Commander (ST205 specific) £650 +p&p
post Jan 20, 2009 - 9:45 AM
miguelst205
Joined Apr 14, '08
From Paraguay
Ok guys.. thanks for the help.. I'm going to register in both forums and participate...
Last question... do you like the POWER FC or you preffer another EMS???.. if it's plug n' play better.. I'm wait for your recommendations..
post Jan 20, 2009 - 11:23 AM
jackett
Joined Dec 11, '06
From Ireland
QUOTE (miguelst205 @ Jan 20, 2009 - 2:45 PM) *
I'd say pick the EMS your local tuner tunes. I have a power fc on my ST205 and I think it's great. If I had the money I would have gotten a Motec but at the same time for my power goals it would have been overkill. And lastly if you do buy a Power FC you do not need the boost control kit from Apexi to control the boost. The Power FC can control it via the vsv.
post Jan 20, 2009 - 12:03 PM
miguelst205
Joined Apr 14, '08
From Paraguay
QUOTE (jackett @ Jan 20, 2009 - 1:23 PM) *
Here the tuners use a FUELTECH.. it's a brazilian EMS, it's medium quality but not complete like another EMS, it's a little difficult to install in the ignition too, but is simply to operate.. but doesn't have a idle controller, Air Conditioner Correction, etc, etc.... I like the MOTEC, the best cars use it, but the price is the problem....
I like the Power FC because it's apparently easy to operate, the installation is quick, use all of the originals sensors and isn't necessary a re-wiring... I have a SBC Blitz i-color as a Boost Controller...
so.. I'm waiting for a Argentina Motec answer... and depending of the price I will decide if I buy the power fc or not...
It's easy to operate and tuning with the Power FC???..
post Jan 20, 2009 - 1:30 PM
jackett
Joined Dec 11, '06
From Ireland
I got mine tuned by a local mapper but anytime I've needed to slightly correct the map I just gave him a call and he told me what to do via the hand commander. If you bought the datalogit software and had the know how you could do it yourself.
I don't know if you have seen this link before but it is a great resource if you have a Power FC : http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
post Jan 20, 2009 - 1:50 PM
miguelst205
Joined Apr 14, '08
From Paraguay
Yes I see this site.. it's very complete... I think the datalogit it's very important to adquire... so, with the power fc, the commander and the datalogit is the pack to buy.. hehe..
Why do you need to correct the map anytime???.. do you put upgrades or why??..
Thanks for your attention and patience man..
post Jan 20, 2009 - 3:24 PM
Cuts_the_Pilot
Joined Dec 15, '02
i also bought the datalogit software, make tuning much better and easier.
you need to retune when major modifications are done, for example when i made and installed a custom plenum a retune was needed, when i installed a cold air intake it was not.
you cant buy the datalogit software as a package, they are made by two completly different companies.
as has been said buy the ecu your tuner is most familiar with.
post Jan 21, 2009 - 9:55 AM
miguelst205
Joined Apr 14, '08
From Paraguay
QUOTE (Cuts_the_Pilot @ Jan 20, 2009 - 5:24 PM) *
Ok man, thanks.. I'm gonna think about this.. because everybody advise me to use the ecu with my tuner is most familiar...
thanks for the help guys..
post Oct 12, 2010 - 5:10 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
im selling my Apexi + commander right now on ebay. if someone wants it, 840$ + shipping. i wouldnt want to sell through ebay as they take 7% commission.
its a gen3 sw20 PFC. it was previously converted by brash boy for ST185 with their own maps and settings, i installed SW20 maps back as I have sw20 gen3 mr2. works great!
This post has been edited by BriinumsBo: Oct 12, 2010 - 5:19 AM
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Oct 12, 2010 - 5:14 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Grave digger, check the date.
Lo-Fi Version Time is now: April 22nd, 2025 - 7:20 PM
