![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) ![]() |
I'm definitely going to install this when I get home. Does Windows Update and all the sort work?
This post has been edited by GotToyota: Jan 12, 2009 - 3:41 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) ![]() |
I donwloaded it last night and im gonna install it on my old desktop right now.
![]() -------------------- ◊◊◊ My F/S Thread! ◊◊◊
Windows update is functional and is on the beta.
![]() ![]() -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Anyone played any games on their copy? I play a few games and I still want them to be playable.
So does win7 really have sub 30 second boot times as claimed?
i guess ill see soon... -------------------- ◊◊◊ My F/S Thread! ◊◊◊
You can always alter that through regedit, that's what I did with Vista and XP (made it 5 seconds instead of 30).
You can always alter that through regedit, that's what I did with Vista and XP (made it 5 seconds instead of 30). really, in what parts of regedit? i've never seen anything to reduce the boot time! Please tell! my xps laptop takes FOREVER to load vista!!!!! -------------------- ◊◊◊ My F/S Thread! ◊◊◊
BTW, make sure you guys install this...
http://www.mydigitallife.info/2009/01/08/f...pdate-download/ There is a bug in media player that will cut off parts of your mp3 files (the actual files on disk). So install it before playing any mp3s. -------------------- 15PSI - 30MPG - Megasquirt Tuned
You can always alter that through regedit, that's what I did with Vista and XP (made it 5 seconds instead of 30). really, in what parts of regedit? i've never seen anything to reduce the boot time! Please tell! my xps laptop takes FOREVER to load vista!!!!! For faster shutdown: Go to run and type in regedit. From there, go to "HKEY_LOCAL_MACHINE", then "SYSTEM". From there, you will see ControlSet001, ControlSet003, and CurrentControlSet. On each one, click to expand them and click control. After this you will see options in the window, right click "WaitToKillServiceTimeout" and choose modify, change it to "5000". This changes the shutdown time to 5 seconds instead of 30. For faster bootup: Go to run and type in msconfig. Go to the "BOOT" tab, and you will see a timeout window with "30" in there, change it to "3". This works on both Vista and XP. -Matt |
I rock a solid state disk, so my bootup times are already super fast!
Screen shots. Let me know if you want something specific.
![]() ![]() ![]() Resource usage on my small 1.6Ghz atom and 2GB RAM (if you can't read it, it says 02% CPU, 34% RAM) ![]() Disregard the performance scoring. I haven't even ran it, so it says my system sucks. (Yes my system is called Verne, because it's a mini ![]() ![]() This post has been edited by 95CelicaST: Jan 12, 2009 - 7:53 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
![]() Enthusiast ![]() ![]() Joined Apr 23, '06 From Rochester, NY Currently Offline Reputation: 8 (100%) ![]() |
just installed it. works great so far. very quick to open programs, and no delay after clicking.
Erich |
Lo-Fi Version | Time is now: February 13th, 2025 - 7:11 AM |
