![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
There is something definitely wrong with mine. First, my brackets don't look like those posted above. Second, my bracket hits the side of my hood chipping the paint off. above the bracket is far from the hood. My bracket does not even sit flat. Also even when I do force it to fit on, the pivot ball of the damper when I close my hood, hits the side of the fender, I tried playing around with the position even adding a washer but still the same thing. I know something is wrong cus I can't fit on either side. The box does say its for our celicas and the dampers are the right size but it doesn't work it keeps chipping the paint of the side of my hood. Any ideas? This is only a 5 minute install for both sides so I know something is wrong.
This post has been edited by trdproven: Sep 28, 2009 - 4:52 AM -------------------- 94 Celica GT
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) ![]() |
Post pics. I received and installed mine last week. So it shouldnt be a bad batch.
ok, imagine the bracket curves like an L and curves with the side of the hood like the pic, mine doesn't either way you mount the bracket the l shape cuts into the paint no matter what position. Bascially instead of the bracket going around the side of the hood, it cuts straight into the hood like scraping it as I tighten it, the bracket dont even sit flat. so I angle the bracket so it doesn't chip my paint. From here everything mounts but as I close the hood, it hits the inner part of the fender.
if I widen the holes will I be able to position it better? I'm thinking as I widen the holes also, it allows the bracket to turn as it goes up and down like it won't stay in place. Unless I use those gripper washers. do you have pics of yours? I can try to widen the holes and life the bracket up higher to see if it gives me room between the bracket and the hood spacing. Did you guys mod yours? Also why does the bracket in the first post have two holes and mine has a gigantic one that looks like it has been already widened? This post has been edited by trdproven: Sep 28, 2009 - 4:59 AM -------------------- 94 Celica GT
I just wanted to bring this up before I start hacking the bracket so that it can fit. I read on other forums that other cars they had to mod it also.
Enthusiast ![]() ![]() ![]() Joined Jul 14, '08 From St. Louis Currently Offline Reputation: 2 (100%) ![]() |
pics could help. If needed, I could take some better pictures of mine this evening after work.
-------------------- '99 Celica GT - Sold
'11 Mazdaspeed3 |
Enthusiast ![]() Joined Apr 2, '07 From Calgary, Alberta Currently Offline Reputation: 1 (100%) ![]() |
Got mine in the mail today
Will install them over the weekend and let you all know how it went. **Update took me no more than an hour to fit them both in didn't use the locking washers though cuz it was a little too thick. Just used normal washers This post has been edited by Artega: Oct 12, 2009 - 8:59 PM |
i believe this fitment will be fine with the dry old paint inside a hood because scratching it wouldn't matter, but I have a freshly painted engine bay and hood that I would like to protect.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
my struts don't move up and down...any help with this? first time install, did i get the defected one?
![]() Enthusiast ![]() ![]() ![]() Joined Jul 13, '09 Currently Offline Reputation: 9 (91%) ![]() |
How To – Mounting Bonnet Struts Tools:
10mm socket 10mm spanner Screwdriver Time:@20-30 minutes Here is the package I received. ![]() Lift bonnet and use the bonnet stay to keep it up. Start at the right side of the engine bay (as you face the engine from in front of the car). Although instructions were provided, I found it easier by doing the following: Procedure:
2. Attach the replacement bolt/pivot to the bonnet strut 3. Replace the retaining clip Note: It’s a lot easier doing it this way because, once mounted, you will not be able to get that clip in. ![]() 4. Undo the bolt in the wing that holds the rubber bonnet stop (10mm socket) ![]() 5. Place the 2 washers (supplied) into position and then screw the bolt/pivot into position (10mm spanner) Note: Be careful not to strip the thread, it’s a little fiddly so just take your time and be patient ![]() 6. Remove the retaining clip from the other end of the bonnet strut 7. Attach the replacement plate/pivot to the bonnet strut 8. Replace the retaining clip Note: It’s a lot easier doing it this way because, once mounted, you will not be able to get that clip in. 9. Remove the upper bolt of the bonnet hinge (12mm socket) 10. Place the plate/pivot (not marked – see note below) into position and using the original bolt secure in place (12mm socket). You may need to lift and support the bonnet in order for the original bolt to locate properly. ![]() Note: Make sure that you have the right plate/pivot for that side. One plate/pivot had a sticker on it marked ‘R’, the other had no sticker or marking. The ‘R’ refers to the right BUT is as you sit in the car looking forward. The following picture shows one reason why I attached the plate/pivot to the strut first. ![]() 11.That’s one side done. ![]() 11. Repeat steps 1 – 10 for the other side. Note: The only difference I found was that I had to remove the washer jet tube located by the bonnet hinge. ![]() ![]() ![]() 13. Once you have done both sides, you can remove the bonnet stay. It’s retained in the slam panel by a round plastic clip. • Manoeuvre the stay towards you • Wiggle it around a bit and it should easily pop out, leaving the round plastic clip in the slam panel • Remove the plastic clip by easing it out with a screwdriver. ![]() 14. Job done. ![]() ![]() where did you get the kit? this is awesome!!! -------------------- You're here for a good time, not a long time. - Colin McRae When in doubt... Flat out! - Colin McRae Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.... |
![]() Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) ![]() |
I also want to know, I cannot find them anywhere??????? -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Enthusiast ![]() Joined Jul 28, '09 From Christchurch, New Zealand Currently Offline Reputation: 1 (100%) ![]() |
call me dumb but what does this actually do for the car?
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) ![]() |
call me dumb but what does this actually do for the car? it allows you to eliminate the hood prop rod. Makes the hood open and stay up by itself once you give it a little lift -------------------- ST205 Crew represent
![]() Challenge Accepted |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) ![]() |
I dont see why you need to be so careful with carbon hoods. We just use a single instead of one on each side cos the hood is so light. It raises up about the same speed and works just fine.
Enthusiast Joined Aug 20, '11 From Toledo, OH Currently Offline Reputation: 0 (0%) ![]() |
Wonder if these will work for other gen celicas.......
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) ![]() |
Thanks to your awesome write up I was able to install these in 15 minutes.
Lo-Fi Version | Time is now: April 23rd, 2025 - 9:22 PM |
