> Help with HID wiring
post Jan 17, 2009 - 6:52 PM
denqua
Joined Jan 17, '09
From CA
i got every to work with the relay but once i turn on the high beam, everything go dead and i cant get it to work any more. I use the stock wire from the low beam to go into the relay and ground it but im not use what to do about the high beam. thx in advance
post Jan 24, 2009 - 9:12 AM
Tom88
Joined Jan 10, '09
From Surrey
So are you fitting two HID kits? It should be as simple as just connecting the two wires from the bulb your converting to HID into the wires coming the ballast. If it doesnt work youve got the positive and negative the wrong way round i think so try chaging them round?
post Jan 24, 2009 - 3:14 PM
plasticgeordie20...
Joined Jan 3, '09
From Middlebrough, UK
Mine just plugged directly into the existing bulb plug no need for a relay.
post Jan 24, 2009 - 10:16 PM
trdproven
Joined Aug 2, '05
From Guam
That either sounds like the older type HIDs or the ones people don't want. Typically HIDs just plug straight through to your existing socket, like you are replacing a regular bulb nothing fancy. no relays.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: December 12th, 2024 - 8:04 PM
